Unexpected WOT!!!!!
Old Mar 4, 2011 | 08:21 PM
THEBIGBULLY's Avatar
Unexpected WOT!!!!!
Finally have had the truck running perfect for over 2 weeks.
I was having an issue with the TPS so I downloaded the sticky and cleaned her up and again was running awesome.
Was driving back from getting the mail and just cruising along about 80kmh or so barely touching the throttle and BAM, WOT
Since our range road is all ice and snow I did some insane fishtailing and fighting to stay out of our 6-8' deep ditches I shut off the ignition and stopped in the middle of the road.
I thank the powers that be I wasn't in traffic!!!!!
I was too impressed with the tire marks to even think about the truck for about 5 min.
I started it up and WOT.
I got under the hood and everything looked good.
Started and stopped about 4 more times and the 5th time it idled fine.
Dropped it in low and drove the half mile home (didn't use the throttle)
Put it in the shop and shut her off.
Started it and WOT 3 more times.
Then no starting at all.
Tried the lift pump (brand new) and can only get one pump out of it. Try as I may I can't seem to find the lobe.
Small amount of fuel seeping under the lift pump mount.
I have fuel slowly dripping off my wiring harness. Can't see where the fuel is coming from. Feel pretty stupid saying "my wires are leaking"
I turned the engine over and am getting fuel out of the bleeder screw.
I undid the fuel line from the tank and pressurized it and good flow.
Cracked all my injectors and had 2 and 4 spurt and the rest is foamy fuel.
I can now get it to barely start with full go pedal but it BARELY runs and makes TONS of black exhaust.
Like I said in the beginning, truck has been running perfect.
Any takers??? All suggestions gladly welcome.
I'm thinking it's time for a piston lift pump.
And I'm curious to have a look at the governor spring.
Pete
Old Mar 4, 2011 | 08:24 PM
Richie O's Avatar
366 Spring Chicken
Wide open throttle has nothing to do with lift pump. You have issues in the injector pump.
Old Mar 4, 2011 | 09:06 PM
TIMMY22's Avatar
She went Toyota on ya Aye?
Glad to hear no one was hurt.
Something sticking somewhere.
Old Mar 4, 2011 | 09:11 PM
Onemoparnut's Avatar
X2 this is not a lift pump problem it has to be in the injection pump. Weren't these pumps recalled for doing just that.
Old Mar 4, 2011 | 09:16 PM
Richie O's Avatar
366 Spring Chicken
Some of the 92's had a recall for them going wide open. My 92 has had it replaced before I got it. My pump is silver and says MOPAR on it.
Old Mar 4, 2011 | 09:19 PM
91 .5's and 92' i think were recalled. You can look up your VIN on Dodge's website and see if you have any recalls....
Old Mar 4, 2011 | 09:51 PM
huntinguy's Avatar
recall info. http://dodgeram.info/tsb/recalls/605.htm
Old Mar 4, 2011 | 10:09 PM
genesag's Avatar
I had a '92 that was recalled due to injector pump. The recall stated that due to a pin inside of the injector pump that could dislodge and cause WOT all 1992 Dodges pickups equipped with 5.9L Cummins diesels were recalled and were not to be driven until the injector pump was replaced.
Old Mar 4, 2011 | 10:38 PM
Originally Posted by huntinguy
I don't have a tag on my pump.
If you look on the sticky "leaky fuel pin" it has an exploded diagram of parts.
What part # am I looking for on the diagram when I gut the pump tomorrow??
I checked the site and no info came up on my truck.
Old Mar 4, 2011 | 10:41 PM
My pump is black and says "nothing" on it.
Old Mar 4, 2011 | 10:49 PM
huntinguy's Avatar
picture #7 I think the littlie pin on the bottom of the lever is what breaks.https://www.dieseltruckresource.com/...2&postcount=19 Part #95
Old Mar 4, 2011 | 10:51 PM
huntinguy's Avatar
Something in the Fulcrum lever beaks. I think there are two pins holding it together if I remember right. Could be one of them.
Old Mar 4, 2011 | 10:58 PM
Richie O's Avatar
366 Spring Chicken
Also they had a symbol they stamped into the pump to show if it was done. something like a figure 8 if I remember. There is a video on youtube ( factory dealer tech type thing ).
Old Mar 4, 2011 | 11:00 PM
huntinguy's Avatar
https://www.dieseltruckresource.com/...4&postcount=10 Video's
Old Mar 5, 2011 | 07:13 AM
TIMMY22's Avatar
Saftey recalls never expire.
