Uh, how do you set the clock...
Old Oct 10, 2006 | 07:50 PM
DarkStar's Avatar
Question Uh, how do you set the clock...
in the 1992 d250?
I have a 92 D250 LE with stock radio and I would like to know how to set the clock on the darned thing.
Anyone know how to do this, I'd sure like to know..
Thanks
Old Oct 10, 2006 | 09:08 PM
Micaiahfied's Avatar
hey welcome to DTR. i don't have the stock radio in the truck anymore, but it is in the garage. i took a look at it and seem to remember having the radio off so just the clock is showing and hold the set button until the clock blinks? or maybe it was in and clock was showing. pretty sure you just have to hold the set button for several seconds. anyways, hopefully i am right. if not i am sure someone will come along soon with the correct way.
Old Oct 11, 2006 | 06:22 AM
DeanM's Avatar
I seem to remember to hit the P button, then when the clock #'s flash turn the volume to change the #'s, then I just shut the radio off and it remembers. I think that is how it works.
Dean
Old Oct 11, 2006 | 06:47 AM
Boatnik's Avatar
On mine, the factory radio/cassette player has two buttons to the right of the display. The top one is marked "H" and the lower one is marked "M". I use a ball point pin or nail to push the buttons because they are small and recessed. No other action is required.
Old Oct 11, 2006 | 07:30 AM
ofcmarc's Avatar
Some of the old stock radios had a "clock" or "clk" button that you would hold down until the clock started flashing. then you would use the tuner **** to change the time.
Old Oct 11, 2006 | 05:44 PM
With the radio on and the clock displayed:
Press SET, the display will say "P"
Press SEL and the hour will be displayed, rotate the tuner **** to change
Press SEL again to do the minutes
Press SEL again to finish
Old Oct 11, 2006 | 05:57 PM
Trebor's Avatar
I found a LAZY way of doing it but it only works once a day. At 11:59 am I pop off a battery terminal & at noon I put it back on! Works every time.
Old Oct 12, 2006 | 09:22 AM
Chrisreyn's Avatar
This is how my 91 stock radio is.......
Old Oct 12, 2006 | 10:02 AM
BigWaylon's Avatar
blah...it works TWICE a day...you just have to be awake later...
Greg
Old Oct 12, 2006 | 12:26 PM
Rammer64's Avatar
If you have the owners manual for your year, it will show you how step by step. It also depends on whick radio you have. They all STOCK radios.
AM, AM/FM, AM/FM/CASSETTE, and they are different...
Old Aug 31, 2016 | 05:59 PM
Seth Beedy's Avatar
This is the correct way to do it for the chrysler infinity radio
Old Aug 31, 2016 | 07:10 PM
Wow that is an old thread to be looking at!
Old Aug 31, 2016 | 10:02 PM
j_martin's Avatar
Greetings Seth, welcome to DTR.
As you may have noticed we have a lot of information here. If you respond to a 10 year old thread, we may poke a little fun at you, but it's all just fun.
What truck do you drive? What mods? Tell us about it. Put a description in your signature (go to user cp) so it follows you around here.
Old Sep 2, 2016 | 03:21 PM
bmouser's Avatar
Go to Crutchfield, get new radio for less than $100, install new radio, follow directions with radio to set clock..... you will not be disappointed.
Congrats on the new ride.
1985cucv
Mar 30, 2010 09:27 PM
jesussaves
0
Apr 21, 2009 12:04 PM
Dodgezilla
Sep 23, 2004 04:21 AM
Stamey
Dec 31, 2002 10:30 PM
crossy
Dec 3, 2002 06:02 PM
