Turned up pump more...have a few questions??
Old Oct 24, 2006 | 05:56 PM
89dieselkong's Avatar
I put another 1 1/4 turns on the full power screw (2 1/4 total) and everything seems to be ok. When i stab the throttle, it immediately settles back down, but the questions that I have is that when I do that, it seems to go below the set low idle for a split second, and then jumps right back to idle. I went for a quick ride and everything seems fine (other than the wicked grin on my face )
Old Oct 24, 2006 | 07:00 PM
Boatnik's Avatar
Sounds Ok to me
As long as it's not wanting to "take off" when you hit a certain RPM, or "hang" when you shift at high RPM it is OK. Mine wanted to take off when I hit 2k, but would drop right down to idle if I released the pedal. I remember Monty posting that his was fine at low RPM, but a high RPM declutch to shift left the engine hanging around at the top end.
What's your idle set to? They do tend to droop on recovery if the idle is set low.
Old Oct 24, 2006 | 07:08 PM
90firstgen's Avatar
Mine does this too since the last time I turned my pump up. Makes me mad because I'll shift gears and let out on the clutch and right when I do that.... It recovers and makes a nice big jolt followed by a clang sound that I'm sure is great for the powertrain
I'll try setting the idle up a little like wanna said and see if that cures it. I hate having to wait an extra second or two to engage the next gear
Old Oct 24, 2006 | 07:28 PM
I'm not sure what the idle is set at (no tach) I lowered the idle a little bit because it did it at a higher idle setting as well. I have it at the same idle I did before I turned the screw. It doesn't hang at high RPM when I shift, but the throttle does seem a lot jumpier now...like when I hit the pedal it jumps more than before. Is it the extra fuel that is being added? Any way to check idle speed without a tach?
Old Oct 24, 2006 | 07:41 PM
G1625S's Avatar
Just turn the idle up a bit and see how it reacts. I like a low idle (about 700) and I have to drive around it at times because it will drop a bit low when I depress the clutch. The throttle will seem a bit jumpier (sp?) because the fuel screw essentially changes the geometry of the governor mechanism.
Old Oct 24, 2006 | 08:07 PM
Thanks for all the replies everyone...new territory, but I'm likin' it!!!
Old Oct 25, 2006 | 03:43 PM
pred's Avatar
Keep an eye on your EGTs, and boost, when i turned my fuel screw up, all the way,,, I started to hit 45 lbs boost, the egt it 1500 as well pretty easy,
I read your mods, and you have the same stock turbo and injectors i have, I have been informed by the great guys here that your baby H1C is not made for high boost,, I bumped my timing anout 1/8" and it dropped my boost to about 32 lbs, trying to keep the baby H1C for a bit,
Peter.
Old Oct 25, 2006 | 05:10 PM
Right now I am hitting about 31lbs full boost and 1200* on the pyro WOT in 5th, haven't been able to make it go any higher in any gear or road condition (hill etc.). Not quite sure where to go from here. New full pin or turbo mods?
Old Oct 25, 2006 | 06:44 PM
G1625S's Avatar
Sounds like you've got optimum tuning for your current combo. Adding more fule will put you over 1200*, meaning you'll have to start watching the pyro instead of the road like the rest of us. A turbo upgrade would buy you some headroom for more fuel...a fuel pin would put you over the edge.
Old Oct 25, 2006 | 07:18 PM
Monty's Avatar
On mine, when you accelerate, push the clutch in and shift at say 2400 etc, the engine takes just a little longer to come back down to a normal in between shift RPM. I find myself in between shifts, waiting for the RPM to drop down before I put it into gear.
I have it set now to where it will not do this unless I go just a little bit further in with the screw.
Old Oct 25, 2006 | 08:38 PM
bigragu's Avatar
Peter.
Check my sig, guys. How in heck do you all hit these high boosts and rpm's? Seems that i've done everything by the book, but I have been boggled by your boost #'s. I have the autometer 35 psi boost...I know, some of you have said not to waste $$$ on these, especially since a 0-60 psi can be had for the same amount. I went with what Diesel Guru said and got a PDR hx 35 16cm Hybrid, but no way am I making past 23 boost and 23 rpm. What the hey?? Don't suggest boost leaks, because my new W250 that I just outfitted with guages just 3 days ago does the same thing. Maybe I need to go to the dealer and have him tweak for me...not!!
Old Oct 26, 2006 | 09:00 PM
So if that is the case, what would you recommend for a turbo upgrade that would compliment a new fuel pin? Any other suggestions for more power? I am guessing that if I am at optimum tune than I don't have much left for "free" power upgrades? Most of my driving is town/highway with limited towing if any. Mostly hot rodding...
Old Oct 26, 2006 | 10:44 PM
pred's Avatar
Well,,, you could always through a snowstage ll water/meth system in, Yu will feel the differance, and drop your egt,s at the same time,, But you boost will come up a bit, when i first installed mine, and the #2 was giving me 45 boost, that water meth hit, and i pegged the boost gauge, I am on the fence now for my lil turbo, Need more air!
92smokin blacky
Mar 19, 2010 11:39 AM
bansh-eman
15
Sep 21, 2009 11:11 AM
GoodoleBob
Sep 27, 2006 11:37 PM
NoSparkplugs
Aug 5, 2006 12:17 AM
pwrtripls1
Dec 20, 2005 06:02 PM
