turbo problems
Old Apr 13, 2008 | 02:57 PM
staken's Avatar
turbo problems
i thik im loosing my turbo idont know but ill tell you all whats happen boost gage bonses rappiley in 4th ger at 10 to 15 pounds and the same at 5ht ger to and then it leavels out then on hood above the turbo the pant is bubling and ciping off but its the only part of the hood thats like that hers some pics of what it all looks like
pant chiping on hood above turbo
exsot hed discoler
[IMG]ttp://i280.photobucket.com/albums/kk178/cumminsman242003/PICT0167.jpg[/IMG]
let me know if thats what s happen
Old Apr 13, 2008 | 03:05 PM
Alwaysworking's Avatar
alwaysonDTR
does you hood have the noise deadner on the bottom of it?
Old Apr 13, 2008 | 03:12 PM
staken's Avatar
no i took it off like 6 munths ago when i got it soked with mudd wotter and this just happend like in the last week one of my friend s sed i mught be loosing the baring
Old Apr 13, 2008 | 03:17 PM
alwaysonDTR
have you pulled the exhaust pipe off and the air intake off and checked for bad bearings/ worn out turbo?
is the paint on the under side of the hood, look burnt like its getting really hot? the paint isn't that good to begin with, mine has all those bubbles and the paint has big flake off spots, now you can see the primer under the stock paint.
Old Apr 13, 2008 | 03:54 PM
staken's Avatar
no havent yet don t have the tool at home ther all at work and dont have the time yet but i still have all the power i wont thoue
Old Apr 13, 2008 | 06:53 PM
Can't tell by looking at the outside unless there's a big chunk missing.
Pull the air cleaner hose off the turbo. If you see oil in the turbo, that's bad,. If it is clean and dry in the turbo, try to wiggle the shaft side to side. If you can't make the wheel hit the housing, the side play is OK. Next try to pull and push the shaft front to rear. If you feel ANY play whatsoever, that's bad.
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
Ada381
Feb 10, 2008 07:58 AM
95 Dodge
Jul 2, 2006 03:28 PM
mj44
15
Dec 5, 2002 10:32 PM
