which turbo to get
which turbo to get
i am upgradding my turbo and trying to decide which one between the hx 40 or htt stage iv i have the mods in my sig and am also gettting pods i tow once in a while usually a horse trailer or a loaded goose neck not over 12000 pounds including trailor weight and am wondering what are some of the pros and cons of both turbos all around and which would be a better turbo for mostly just street driving
gray93,
POD's flow a good amount of fuel. For usable horsepower, I would opt for something with a 4" exhaust outlet. An upgrade is almost like a temporary fix. If you can afford it, get a 62-14 w/ a 71mm exhaust wheel. If you do decide on a 60mm upgrade such as the Stage IV, you may or may not have EGT issues with POD's as your pump tuning will affect that; get a custom set of injectors with the correct spray pattern if you go that route.
Aloha,
Matt
Aloha,
Matt
I am running pod's and pump tweaked. I am looking at the hx40/16cm wastgated. I think a 14cm wastgated would be fine and am also considering that route. I haven't actually run it so this isn't a ton of help I know. Just talked to a few folks. I do have a 16cm non-wastegate w/ stock compressor and it made a world of diff. over the stock housing.
It all depends on how much money you want to spend. The HX40 will flow more air and keep EGTs in check better than a stage4 kit. How much, I dont know. Keep in mind that with bigger wheels on each side, the 40 will spool slower than a stock or stage4'ed turbo.
What kind of EGTs/ boost do you see now? I wouldnt get too anxious about turbo upgrades unless your EGTs get out of hand, or you top 30psi with the stock turbo.
Daniel
Daniel
Bradleysram
19
05-12-2009 08:36 AM
Badd Dogg Guy19
29
10-18-2006 07:44 AM
blackdiesel
09-05-2005 12:17 PM
