turbo barking / chirping
Old Jun 23, 2011 | 11:35 AM
Oldblue813's Avatar
ok so I put a wastegated exhaust housing on my truck sometime ago. And so far if you accelarate harder than normal or if you put a tremendous load on it starts chirping then if you suddenly drop the throttle to nothing it barks, loudly. The intake side of the turbo is the factory size. Anybody got a suggestion, or a replacement setup that I need to look for that could be better than this.
Other than this problem the setup works, absolutely no lag and im pushing 45 psi on the boost gauge.
Old Jun 23, 2011 | 12:34 PM
BILTIT's Avatar
What housing on what turbo?
Old Jun 23, 2011 | 12:40 PM
Oldblue813's Avatar
its a factory intake side, and then the exhaust side is off a 97 12 valve
Old Jun 23, 2011 | 12:41 PM
BILTIT's Avatar
What year of truck do you have?
Sounds like you are over-speeding the turbo and running it outside of the efficiency range, especially at 45psi.
A better turbo that spools well is the HE351CW off 04.5-07 dodges. Its not complete bolt-in but many have done it with minimal changes.
Old Jun 23, 2011 | 01:13 PM
Oldblue813's Avatar
i have a 92 w250 5 speed
st 45 psi though it seems to be ok its actually around the lower end bout 15 - 20 this is happening at
Old Jun 23, 2011 | 01:26 PM
Falcon1's Avatar
Get a new turbo.
Old Jun 23, 2011 | 03:18 PM
It's compressor surge caused by not having MWE slots. You can install an upgraded compressor section. HTT and Gillette Diesel used to be the sources but I've been away for a few months.
Old Jun 23, 2011 | 05:54 PM
ARbowhunter7's Avatar
^^^This
Gillette is backed up pretty bad on the compressor upgrades. Their lead time is sickening. The best price I've seen on the 60mm upgrade is at Big Bad Diesel performance. Not sure what their website is called but Google will pull it up. They're very 1st gen friendly
Old Jun 23, 2011 | 06:02 PM
Bencie's Avatar
Had the same problem on my 92 when I installed a 12cm housing, Wannadiesel steered me in the right direction and I did the 60mm wheel and housing from Gillette and problem solved. Thank you Faith
Old Jun 24, 2011 | 09:50 AM
Douglas2's Avatar
hey-Hey!!!,
Given that you're seeing surge, go for the 8-bladed wheel. Its surge line is across lower flows at a given pressure than the 6-blade variants( based on HX40 maps that these compressors spring from ).
cheers,
Douglas
turbos10
Jun 16, 2010 08:57 PM
gman07
Apr 15, 2006 08:32 PM
ciscohusker
19
Sep 11, 2005 12:51 PM
j28s
Feb 11, 2003 08:03 AM
Maddog
Jan 2, 2003 09:57 PM
