Turbine houseing question
Old Jan 19, 2007 | 10:54 AM
efbeason's Avatar
I am contemplating swapping the turbine housing on my 1989 stock turbo. Should I put a 14cm or a 12cm? What are the ups and downs of both. Thanks!
Old Jan 19, 2007 | 11:08 AM
loch's Avatar
spool is faster, but it cut top end down some. Id uts an auto you wont see a massive diff.
Old Jan 19, 2007 | 11:13 AM
1stGen545's Avatar
I have had both on my 92. The 12cm came on fast (especialy compared to the factory 21cm) bilt more bost but EGTs came up a little. The 14cm was not quite as fast but close but ran a little cooler. But I also had POD's, and lots of pump mods. then I went to an HX-35 14cm and it ran grate but now i'm going with a HX-35/40 hybrid so that I can keep my 14cm. I was not a fan of hybrids but I found out that the shaft and exhaust wheel are the same size, (the compressor wheel will bolt right on). In short you will love the 12cm or the 14cm I ran both with the wastgate wired shut just watch your boost H1C-30psi max recominded HX-35-36psi HX-40-40psi more than that you are super heating the air and it is becoming thin and will have less oxogen in a given volume. Especialy on a non-intercooled.
Old Jan 19, 2007 | 11:33 AM
loch's Avatar
The 89 already has a 18 not a 21, why i said not a massive differance. Money be better spent getting a turbo.
Old Jan 19, 2007 | 11:55 AM
Underpsi's Avatar
Ya I agree definitely don't get a 14, they cost way to much compared to a whole hx-35 with a 12cm. If you don't want to go to serious then just buy a used hx-35 with the 12cm and it will be much better
hairy bean bag
May 3, 2006 09:05 AM
keithplacervill
Jun 23, 2005 12:15 PM
shoe
Apr 7, 2005 05:56 AM
Ocmechanx
Mar 23, 2005 11:49 AM
mooseman
Dec 20, 2004 08:52 AM
