Truck stumbles past 1/4 throttle
Old Jan 11, 2007 | 05:31 PM
SMOKE' EM's Avatar
My Truck stumbles past 1/4 throttle it feels like i hit a wall any time i go past 1/4 throttle i just replaced the lift pump last night after this started happening i also bleed the injectors a couple times any more ideas on wat could be wrong, this started happening yesterday morning
Old Jan 11, 2007 | 05:36 PM
Change the fuel filter if you haven't already. It sounds like a restriction problem.
Old Jan 11, 2007 | 06:03 PM
SMOKE' EM's Avatar
i just changed it this past saturday
Old Jan 11, 2007 | 06:19 PM
Hmmmm. It starts up OK, you don't have to bleed it?
Old Jan 11, 2007 | 07:21 PM
SMOKE' EM's Avatar
ya it always started fine i just started over and bleed the injectors the fuel filter and the line from the lift pump and it seems to run alright i primed the lift pump for awhile to
Old Jan 11, 2007 | 08:46 PM
90firstgen's Avatar
I would think its the fuel filter too. You might pull the filter off and dump it out to see if its plugged full of crap. You might have gotten some bad fuel. Otherwise I'd look into the lift pump.
Dan
Old Jan 12, 2007 | 11:54 AM
dpuckett's Avatar
Not to rain on your parade....
Is there something internal in the IP that could be causing the stumble? It seems like some have had the same problem, and something was amiss inside.
Daniel
Old Jan 12, 2007 | 05:23 PM
Yep, just trying to eliminate the simple and cheap stuff first.
chuck'64
Mar 24, 2009 05:20 PM
Common
May 2, 2008 11:25 AM
goffracing
Feb 27, 2008 08:31 AM
07SC2500
19
Oct 19, 2007 10:51 AM
dma251
May 7, 2003 08:18 PM
