Truck quits running
Old Feb 21, 2006 | 08:21 AM
kc8ksg's Avatar
Exclamation Truck quits running
Okay it doesn't just quit all together, it acts exactly like if you shut the key off then back on, and only does it at WOT at higher RPMs (2500-2700) It doesn't die, you just loose the throttle till it comes back down to about 1000rpms or so, or back to an idle, which is exacltly what it does if you just turn the key off and back on for a second. It doesn't do it all the time just once and a while, maybe 2 times in the 5000 miles I have put on my truck, but today, it did it 5-6 times. Hopefully some of ya'll have had this problem and it is an easy inexpensicve fix!!!
Chris
Old Feb 21, 2006 | 08:29 AM
Grey Wolf's Avatar
Try checking the connection to your fuel shut off solenoid it may be loose..
Old Feb 21, 2006 | 08:32 AM
kc8ksg's Avatar
That was one of the things I was thinking of, however I have no idea where the fuel shutoff seloniod is, could ya maybe give me an idea where to look, or maybe some links to some pics?
Thanks!!
Chris
Old Feb 21, 2006 | 08:34 AM
lovemysan's Avatar
Yep I would use some dielectric grease on the connectors and recrimp for more grip. Its a common problem.
Old Feb 21, 2006 | 08:39 AM
lovemysan's Avatar
Okay the location for the FPS is just above the injector lines coming out of the back of the injection pump. It will have 1 or 2 wires coming off of it. It threads down into the pump vertically. I believe it it 15/16" in diameter. Just pull the connectors off and give them a squeeze with some pliers.
https://www.dieseltruckresource.com/...=faq&faqnr=110
Old Feb 21, 2006 | 09:22 AM
kc8ksg's Avatar
okay, so I assume, that if I unhook the right thing while it is running then it will quit running, so I'll know I am messing with the correct thing, right?
Chris
Old Feb 21, 2006 | 09:37 AM
Chrisreyn's Avatar
Chris, If you have a hard time find the Ffuel Shut-Off Selinoid, let meknwo and i'll get a pic for you.
This thread talked about how to test it and such....
https://www.dieseltruckresource.com/...ad.php?t=89696
Good Luck
Old Feb 21, 2006 | 09:38 AM
Chrisreyn's Avatar
BTW I replaced the connector on mine with a ring connector and use the little nut already on the selinoid to hold it on.. should prevent it from coming loose and not making a good connection......
Old Feb 21, 2006 | 09:45 AM
kc8ksg's Avatar
Thanks for the help, and the link to the thread, I will try to find that this evning hopefully it will be good till I get home, so I won't have to try to find it along side the road somwhere!!!
Chris
Old Feb 21, 2006 | 09:58 AM
Chrisreyn's Avatar
I just uploaded a pic showing thelocation of the fuel shut off for you, I'll put it in here as soon as it gets approved...
Old Feb 21, 2006 | 11:34 AM
Chrisreyn's Avatar
Here ya go...
The red ring fitting is the Fuel Shut Off:
I replaced the "slide on " connector with a ring connector:
Old Feb 21, 2006 | 12:32 PM
kc8ksg's Avatar
Thanks alot for uploading that pic, I found that wire and took it off and put it back on hopefully that will correct it, if not I will do what you did and put an end on it to take care of it for good. Mine has two wires and that is what threw me off, I unhooked one and it kept running so I assumed it was the wrong one, but after some looking there were two wires and the second one was the one I needed. I haven't had time to drive it yet so I don't know if I still have the problem, but I know where to look now.
Thanks for all the help!!!
Chris
Old Feb 21, 2006 | 11:02 PM
kc8ksg's Avatar
Well after the 75 mile trip home the truck ran great so I am assuming the problem is fixed for now and the connector was loose, anymoore problems and I will know where to start.
Thanks for all the great help and quick info ya'll!!!
Chris
Old Feb 22, 2006 | 12:36 AM
Chrisreyn's Avatar
WOW....hanging around this site pays off!!! I have finaly been the one to help someone else, instead of the one being helped...
Old Feb 22, 2006 | 08:21 AM
kc8ksg's Avatar
Wink
I know that feeling!!! Maybe if I stay around here long enough I will be able to help somebody too!!!
Chris
MoparMarv
Jul 26, 2008 11:44 PM
Baja
May 17, 2006 11:41 AM
Bob Blockland
May 15, 2005 04:33 PM
matchhead
Feb 18, 2005 06:44 PM
ramit98
Sep 25, 2003 09:35 AM
