truck gets hot
truck gets hot
for some reason my truck gets really hot after about an hour of driving. it is not leaking any water and is always full of coolant. the hottest its gotten is one mark from the "h" does anybody have any reason why it is doing this
Probably needs a thermostat. The original has a small by-pass that allows some to get through so you don't cook it, but it'll still run pretty warm.
i sec the thermostat(cummins)!!!!
when the temp stated to climb,do you here the fan pulling air (fan roar?) if not this could allso be part of the problem.
no not usually
Originally Posted by Buffman88
no not usually
sound like the fan clutch is the problem.......unfornunly chry has discontinued there fan clutch for the 89-91.0 so you will have to go aftermarket.
If you have the option,buy the heavy duty or the one for ac!
smokey94
Nov 13, 2014 03:45 PM
duallydave
Aug 7, 2005 09:38 PM
