4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Truck gets hot when towing
Old Nov 12, 2014 | 11:03 AM
smokey94's Avatar
I have a 2010 6.7 mega cab, I was pulling my trailer and it was getting hot. so I figured it was the clutch fan like my other dodge did when it would get hot. I cant hear it kick on. so I had to have it at the dealership so I asked them to check it out. they checked it with the computer and made it kick on and said its fine. they also said the relay and the sensor is good. so I cleaned the bugs out of the radiator fins . pulled my trailer and still getting hot and cant hear it come on. don't know what to do know
Old Nov 12, 2014 | 02:39 PM
6.7L MegaCab's Avatar
What do you mean by 'hot'? I believe the Cummins thermostat opens around 208 deg F... At least that is where I typically see the temp begin to drop when it gets above 199 on occasion.
Edit:
According to Cummins QuickServe a 180 deg thermostat fully opens at 202 deg F while the 190 deg thermostat fully opens at 207 deg F.
Old Nov 12, 2014 | 07:15 PM
smokey94's Avatar
It gets up to 237 was the highest I have seen it.
Old Nov 12, 2014 | 07:17 PM
smokey94's Avatar
I have it defuel to stock at 220,
Old Nov 12, 2014 | 07:35 PM
That definitely is not good. I never hear mine kick on. How many miles do you have on it? Maybe your thermostat isn't operating properly or the water pump isn't doing it's job?
I recommend signing up for a Cummins Quick Serve account so you can get access to the Cummins Service Manual. You will need the engine code which is near the oil filter if I recall. There are steps to test the thermostat if you don't want to buy a new one.
Old Nov 13, 2014 | 09:06 AM
staarma's Avatar
Mine runs hot too. Dealer said it's normal. They said hammer down and don't worry about it. I have been and not looked back. The truck will start to defuel and limp above 235 until the truck cools down according to them. Never had that happen yet. Funny I've never had the trans get hot in all this time either. The 13 and up trucks got 50% more cooling capacity then previous model years.
Old Nov 13, 2014 | 03:45 PM
BobTipton's Avatar
We towed our 14k fiver from TN to Arizona (where we are now) beginning in September of this year. Truck is bone stock. Occasionally saw 218* on the EVIC for the coolant. Only time tranny seems to heat up is in town in stop and go traffic where we would see around 185 on the EVIC. Never saw above that.
tcb1
Nov 1, 2011 03:33 AM
tcb1
Sep 27, 2011 12:23 PM
Buffman88
Jul 13, 2006 07:43 AM
duallydave
Aug 7, 2005 09:38 PM
