Tried to bomb it now it doesn't run
Tried to bomb it All I did was break it
I changed the governor spring last night. Took the pump top off did the swap. While I was in it I turned up the power screw about two turns. I got it all back together and it ran and idles fine. I took it out on a test run all was good until 3000 rpm in fourth. The truck died like I had turned it off. So I dragged it home. It spins over fine good compression. I cracked the injector line to bleed it. Some fuel came out but not a lot. I then took the pump top off. All looked fine inside. Next up I pulled the fuel solenoid. Tip is a little cracked up but not much. I tried the manual lever on the lift pump. It pumped fine.
Before you ask I have no fuel pressure gauge.
Any thoughts suggestions?
This is on my W350. Getrag. 1993
Solenoid has power. I removed it and tested it. It shot the plunger out. Once re-installed it clicks when power is cycled to it. I just tried to bleed the injectors on it. Some fuel bleed out but not a lot. I went over to my running cummins and tried it. I cracked it's injectors loose and it sprays fuel all over much more than my one ton.
Here is the tip of the plunger.
Is it possible for the tensioning lever to pull out of the control collar when the pump is buttoned up?
Check the lever for the manual fuel pull. I had mine off a tooth and it screwed it up. I'm trying to remember if there is a way to put it on that has it partially engaged too. You kind of get into it when you take that top half of the pump apart. I think I accidentally pulled it off thinking I needed too....
I'm willing to bet this is the issue since you say the plunger is hooked up and good to go. Also, since it ran, now it doesnt. push on the lever so it is pushing towards the front of the truck (NOT the shut down position) and try to crank it again....
I checked where the lever connects to the control collar it moves freely and is connected.
I buttoned it all up and still nothing.
I had the injector nuts loose and very little fuel comes out of the lines. Two of them had no fuel at all.
Now i am wondering if a piece of debris has lodged in the distributor plunger and is interrupting the flow.
Looks like I will need to pull the pump.
It did quit right at the time I first took it to wfo. Maybe I didn't have the throttle lever bolt tight enough.
Was the range of throttle working correctly while it was running? I mean was half pedal half throttle? I ask because if you tightened the fuel screw while the pump top was off it can be really tough to get the pump top back on without hanging up or jamming the afc lever.
I just talked to a mechanic I know who is familliar with these trucks. Told me to pull the pump and get it looked at.
Time to check the sticky.
Soooo, what's that item called that can be broken if the fuel screw isn't taken out? I'm no expert on the internals of this pump, but it's the first thing to came to my mind when he mentioned turning the screw in before reassembly.
dont pull it off yet, i had the same situation, all i did was remove the injector lines from the back of the pump and each one of those fuel line connectors (6) can unscrew from the pump, but be careful there is a spring behind each one, and in side is a very small plunger, i had rubber stuck in those and it gave the same sensation. i did not pull the pump to do this.
hemertwv
18
Sep 6, 2005 11:32 AM
flyfsh70
May 8, 2005 10:33 PM
YinYaker
Nov 10, 2003 12:28 PM
