Just did big service, now truck doesn't run good
Old May 10, 2007 | 04:27 PM
howardA3's Avatar
Just did big service, now truck doesn't run well
Hi everyone, I just did an oil,and filter, fuel filter, manual trans and transfer case fuid change and rear axle oil change. I used mopar atf+4 and mobil 1 gear lube. It was ok after the oil and filter but after the rest of it the truck kind of lugs/bucks sometimes at around 1200-1700 rpm. it felt like it wasn't getting fuel so I replaced the fuel filter. It started better but didn't really make any difference with the roughness. Over that rpm range it runs great and it only happens some times, very intermittent. Any ideas would be great.
Thanks
Old May 10, 2007 | 04:51 PM
HOHN's Avatar
I'd guess you might have gotten bad fuel.
Also, you have to be VERy careful changing the fuel filters on these things-- the systems are very sensitive to contaminants.
I'd run this tank as low as you can and fill up with some fresh stuff, and dump in some good additive.
Let us know if this helps.
JH
Old May 10, 2007 | 05:11 PM
John Faughn's Avatar
We need info on the truck to help you better .
You may have bumped something , the TPS [ throttle position sensor ] may have an issue , it may take a little more driving to get all the air out of the fuel system , double check the trans. fluid , in neutral , mine shutters at 1,200 RPM a very little .
For truck info , if you look under the 1st post some one makes they have a description of there truck & any mods , you fill in that info in the user control panel .
Old May 10, 2007 | 07:19 PM
Box5's Avatar
You didn't put the ATF in the manual trans did you? Just the transfer case right?
Old May 10, 2007 | 07:41 PM
howardA3's Avatar
Yes, that what the manual says to use.
Old May 10, 2007 | 08:39 PM
Box5's Avatar
oh u have a 2006.... i didn't see ur sig in the first post my bad. I guess thats ok then for ur trans if the manual said to...
Sep 26, 2011 11:53 PM
klx650a2
May 25, 2010 03:37 PM
neverenough
75
Mar 19, 2007 07:39 PM
hemertwv
18
Sep 6, 2005 11:32 AM
TomW
Jun 7, 2005 11:22 PM
