>>> trapdoor fuel tank access <<<
I am gonna have to experiment with this.
I like the idea of attaching the extra metal UNDER the hole, instead of on top of the cut-out piece.
The only issue I fore-see though is that the fuel bulk-head is almost against the forward edge of that second bed-cross-member and adding a strip of metal under the hole above it may very well interfere with accessing the bulk-head.
I will have to give it a close scrutiny and see which method will work best for me.
I may go with a combination, having metal attached underneath on three sides of the hole and the fourth piece attached to the top surface of the cut-out.
There are many ways to relieve the 'possum of his hide.
I had to do this to my 1st-gen quite a while ago.Since I didn't dare use an abrasive wheel near a fuel leak, I used a miniature circular saw with the blade depth set to just the thickness of the sheet metal. It got a little warm but at least it didn't throw a shower of sparks.
If it makes you feel any better about cutting a hole in your truck, Chrysler used to build them that way. My Dodge M-37 came from the factory with an access plate just like the one you describe in the bed over the fuel tank.
Mtman6698
14
Nov 18, 2007 04:50 PM
Bart Timothy
Apr 3, 2006 05:43 PM
