Sponsored by:
Sponsored by: CARiD
Why no access panels to the fuel tank top?
Old Mar 30, 2006 | 11:40 PM
Bart Timothy's Avatar
Just curious if anyone knows why manufacturers don't put access panels to the fuel tank top. What's the engineering reason for this? Had to drop the tank on my wife's old Caravan to replace the fuel pump, once. An access panel in the floor would have made the whole job much easier. To get to the tank top on these trucks, the tank either has to be dropped or the bed raised. Seems like there ought to be a better solution.
Old Mar 31, 2006 | 12:06 AM
edwinsmith's Avatar
The simple answer... Cost!
Edwin
Old Mar 31, 2006 | 12:11 AM
Mechanos's Avatar
Because that makes too much sense. I've helped a friend change the intank pump in his 4Runner and sure enough... there is an access panel that can be removed for access so you don't have to drop the tank.
Old Mar 31, 2006 | 12:10 PM
JKM's Avatar
JKM
The truck was designed by an engineer , not a mechanic
Old Mar 31, 2006 | 12:22 PM
fredbert's Avatar
Trust me, the engineer thought of this, but was overruled by a bean counter. The same goes for drain plugs in the torque converter, transmission pan and differential housing(s).
Old Mar 31, 2006 | 01:19 PM
Mike D's Avatar
The knuckelbangers would having less to work on if it was that easy.
Old Mar 31, 2006 | 05:21 PM
Jfaulkner's Avatar
Muted User
I would like to back up this statement with the 6.0 powerstroke. Just raise the hood, you'll understand.
Old Mar 31, 2006 | 05:58 PM
rammtuff's Avatar
Ford put an access hole in the escorts. Easiest 1.4 hrs you could ever make.
Old Apr 3, 2006 | 04:29 PM
lglamb's Avatar
The Audi I had had an access hole.
What I needed was a heated garage.
Old Apr 3, 2006 | 05:43 PM
Scotty's Avatar
Top's Younger Twin
I might venture into doing this on the next truck.
Sounds like a great idea...no wonder it was not implemented.
BearKiller
Oct 4, 2011 07:34 AM
sgrooms
21
Apr 8, 2008 11:17 AM
Mtman6698
14
Nov 18, 2007 04:50 PM
groran
Jul 23, 2007 06:47 PM
Mike M
Jun 5, 2006 11:38 AM
