Transmissions make my head hurt
#46
Cougar,
I just sent you an E-mail on that bracket you need for your swap.
#47
I dI'd the 47rh swap. You don't want a pressure switch. It falls in and out at virtually the same pressure. This will cause the lu to dart in and out at a certain speed which is beyond annoying.
You want and adjustable pressure transducer. It will fall out about 10 psi bellow the lock in pressure. I think mine came at 50psi. Don't remember more.. I think you want it to close at the pressure and not open.
M
M
#48
not all pressure switches are like that. I have an adjustable pressure switch that the turn on pressure is higher than the turn off pressure. I believe its a Hobbs unit. I haven't used it yet but checked it with regulated air pressure.
#49
In order to appease the wife, I've ordered a Compushift Mini. They are building one specific to my application. Nice of them.
#51
Their "off the shelf" version is built around gas engines. They are reprogramming the chip for the lower RPM diesel, different pressure switch, and a matching connector for the stock TPS.
#52
I was kinda nervous about welding a strip on the back of the transmission mount plate and lengthening the the slots as in the FAQ. I was talking to a friend about it and he has a friend with a computerized plasma cutter. So he made me a new plate with the slots moved back an inch.
#54
The 518 went, I have reverse and no forward. So no more procrastinating.
DUALLYDIESEL
12-21-2002 09:49 PM
