Transmission Stop leak ??
Old Apr 17, 2008 | 11:24 PM
92GhostRyder's Avatar
Hey ya'll I was wondering if any of you have any experience in using a stop leak product of any sort in the GetRag tranny? Ive been told they are imfamous for leaking, that they caught a bad rep for bein a bad trans because they leak, people run em outta oil then "BANG". Im going to drop the old oil whatever the previous owner might have run scince im tryin to get all the services done seing as i just bought the truck. Im going to drop 90 weight gear oil in it thanks to the reccomendation of a local very reputable transmission guy and many folks on here. Just wondering if any of you have had any luck with any stop leak products?. I was also curious, is a Pyro gauge the same as an EGT gauge? Thanks fellas. Im not too familiar with after market gauges.
Old Apr 18, 2008 | 12:42 AM
Alwaysworking's Avatar
alwaysonDTR
pyro and egt are the same.
Old Apr 18, 2008 | 05:01 AM
KRB's Avatar
KRB
I can't imagine stop leak patching a hole 90W will flow through but I could be wrong. Most overfill by a quart to be safe too.
Yes, a pyrometer measures the Exhaust Gas Temperatures.
Old Apr 18, 2008 | 05:12 AM
Chrisreyn's Avatar
Dropping 90 weight in a getrag is a bad idea. They lube the bearings and gears by the "splash" method( a gear is half-in half out of the oil resiorvour and throws oil onto the bearings and gears), and 90 weight is simply to thick to allow for proper lubrication. The manufactorer recommends a 30W motor oil.
Drain whatever is in it and refill it with the proper oil, then overfill it by a quart and a half.
If you search in this thread for "overfilling getrag" you'll find countless threads where this has been discussed and several ideas on the easiest way to do it, as well as ideas for fabricating sight glasses and dipsticks for monitoring the fluid level..
Old Apr 19, 2008 | 06:32 AM
KRB's Avatar
KRB
Oh yeah, good catch man - don't know what I was thinkin there. Many full time Dodge transfercases were trashed due to running 90W instead of 30 for similar reasons.
Old Apr 19, 2008 | 04:02 PM
sdstriper's Avatar
Most stop leak products are snake oil. Save your money and fix any leaks you find correctly.
If your reputable transmission guy recommended that heavy gear oil he doesn't know what he is talking about on this particular transmission, someone will correct me if I am wrong, I don't think I am... You will be needing a rebuild if you use it for anything at all with that oil in it.
wyomingcowboy
Jun 16, 2009 10:04 PM
1fstdsl
Oct 24, 2007 08:39 PM
slivertruck
25
Nov 8, 2006 08:35 PM
royta
Nov 6, 2006 08:19 AM
srowen
Jun 2, 2003 10:11 PM
