trans cooler idea
Old Mar 18, 2010 | 08:40 PM
NE frmhnd's Avatar
trans cooler idea
Has anyone run a deep pan, and put a couple fittings in it and set up a small pump of some sort to run into a cooler mounted under the bed? I know where I can pick up a hydraulic oil cooler or two cheap, and it wouldn't divert any flow away from the existing circuit. I could also set up a couple sensors to kick the pump on at a certain temp, then fan(s) on at another. Any thoughts?
Old Mar 18, 2010 | 09:57 PM
dzl_damon's Avatar
I think Dodge had the same idea! It was a factory option!
Summit and JEGs have ones by Derale or something like that I'm gonna use. $140 has thermostat, fan, and cooler. Use it in series with your stock cooler, not parallel to the side. and make sure it has at least AN 8 (3/8") fittings
Old Mar 19, 2010 | 06:37 AM
Jim Lane's Avatar
Are you talking for an automatic or a manual transmission?
You would need to get a scavenger pump that would be able to handle fluids above 300* to survive, either a mechanical,
http://www.racelinepumps.com/re_pumps.htm
Or an electric
http://www.summitracing.com/parts/TI...4/?image=large
pump, if it is going to be in series with the factory circuit then it would have to be at least 1/2" lines throughout but if it was going to auxillary circuit then 3/8" lines would be ok however you would still want to keep the factory lines intact.
On my car I used to have remote oil coolers on both my manual transmission and my differential.
Old Mar 19, 2010 | 06:37 PM
NE frmhnd's Avatar
Yes, an automatic. My thinking was that by running the deep pan and plumbing into it I could set up a separate circuit from what is there. It would circulate the oil out of and back into the pan.
I didn't know about the optional auxiliary cooler when we got it and I don't remember seeing it. But with this busted up knee I can't exactly crawl under it to check real well. What my thought was I could set up three stages of cooling, one the pump turn on, second is one fan, third is the other fan.
I think I am eventually going to run gears somewhere around 3.55s and a gear vendors. I think it has 4.10s now. Top speed is about 65. It's an 89 with 235/85R16s.
torq_crowe
Sep 12, 2008 06:59 PM
wap
Sep 11, 2006 12:44 PM
jrussell
Jun 14, 2006 11:04 PM
Begle1
Jul 13, 2005 04:13 PM
Begle1
Jan 26, 2004 03:03 PM
