tranny lines
Old 12-29-2009, 10:11 AM
rusty250's Avatar
tranny lines
hey guys do u know where i can get replacement transmission oil cooler lines? mine r leakin pretty good, so im stuck without my truck for a bit. its a a727 tranny.
Thanks
Old 12-29-2009, 04:58 PM
Jim5870's Avatar
I've seen hydraulic hoses and fittings substituted for bent steel lines.
Old 12-29-2009, 06:13 PM
93 12v's Avatar
Yeah I gotta fix mine too, it's not leaking , yet. It's chafing on the radiator drain. Regular hydraulic hoses should do right?
Old 12-29-2009, 07:07 PM
JustRamIt91's Avatar
yes make sure you get 1/2 in lines, then use 2 worm clamps or 1 big one if you have them. I had custom hydrolic lines made up for me at work. They also had the nice 1/2" wide worm clamps and that fixed all my leaks :-)
Good Luck.
Degrease you engine after you fix the leaks, trans fluid isn't good to let sit on things. ouh!!!...and bring lots of quaters to wash the degreaser off, use soap function then pressured water. Mine came up real nice :-D
Old 12-29-2009, 09:59 PM
440trk's Avatar
I'm pretty sure the 727 behind the Cummins uses 3/8" lines.
I've bent up several sets of trans lines over the years, and they're pretty easy to do, if you have the right tools. Just take your time and think through what you're doing.
Old 12-29-2009, 11:10 PM
rusty250's Avatar
so hydraulic lines will work. Thanks for the info guys
Old 12-29-2009, 11:13 PM
i've used 1/2" because thats what the cooler lines were. no problems so far.
Old 12-30-2009, 01:11 AM
440trk's Avatar
Is your truck an IC or non-IC truck?
I thought the IC trucks with the OD trans used the 1/2"...but the earlier 727 Cummins trucks used 3/8" ?
Old 12-30-2009, 09:19 AM
mine is a non ic truck, and its the 3 spd 727 and uses 1/2" lines, as far as i know. i haven't gotten around to adding a temp gauge on the hot side but when i do i'll know for sure. I'll probably also add a cooler infront of the fuel tank and remove the one up front.
however i used to have a ramcharger which had a cooler and trans that went, that used 3/8 lines, i had the shop install the new trans and cooler for me. since then i refuse to let a shop do work that i can do myself.
Old 12-30-2009, 09:20 AM
edit- sorry for the double post...idk whats wrong with my girls laptop.
Old 12-30-2009, 06:28 PM
archer39's Avatar
might want to be careful on what type of hydraulic lines you use some are only rated to withstand up to 150 degrees. i ended up getting my lines from discounthydraulichose.com and going with R5 general purpose/truck hose. It had the one of the highest temp ratings and still was some what bendable.
Old 12-31-2009, 10:03 AM
rusty250's Avatar
hey archer how many feet of the r5 hose did u end up getting?
Old 12-31-2009, 07:09 PM
Benjamin b2's Avatar
only thing bad about hose is it doesent disapate the heat as well as steel, just food for thought.
Old 01-02-2010, 12:27 PM
jw216's Avatar
Just bought mine at Dealer $60
Old 01-02-2010, 04:58 PM
GasganoFJ60's Avatar
My metal trans lines started leaking from them rubbing against one another. Took them off and into a machine shop and had them solder the holes back up for about $10. Might be a bit easier than tracking down or making all new lines.
Quick Reply: tranny lines
