thrust bearing question
Old Mar 14, 2007 | 06:29 PM
DODGE 92's Avatar
well i checked my flexplate with a prybar and the only thing thats seems to be happening is the flexplate flexing when i pry on it now i got a question i had some work done on the truck a while back "tranny swap"maybe they did something bad
i need to no is there suppose to be something behind flexplate cause on mine in order i got back of motor flexplate a spacer and flexplate screws is this right
and another thing i talked to shop that worked on my truck i was told that they stripped some bolts on engine adapter so they had to tap all of them 1 size bigger i had to use a 5/8 key to remove them im wondering if this had something to do with the rubbing that i got
work was done back in september but i only used 1 1/2 tank of fuel since then maybe i mistook that rubbing sound for tc malfunction so i changed tc
im out of ideas guys might be thrust bearing but ???
Old Mar 14, 2007 | 06:32 PM
If you can't slide the crank back and forth, then the thrust bearing is OK.
Old Mar 14, 2007 | 06:34 PM
DODGE 92's Avatar
crank
wanna crank does not seem to slide i took a 2 feet flat prybar to it and the only thing happening is flexplate flexing
Alec
May 16, 2015 03:03 PM
woodrat
Dec 11, 2006 02:27 PM
dieslcruisrhead
Sep 15, 2004 10:54 PM
Jeremy Cusick
May 20, 2004 05:50 PM
