Throttle bellcrank part number
Old Jul 21, 2006 | 05:27 PM
Flake's Avatar
The throttle bellcranks shaft's on my `93 are severely worn, I already have new bushings and the rod kit to go on but I need a new bellcrank.
Does anybody have a part number or a source to find the part number?
--Thanks in advance.
Old Jul 21, 2006 | 06:19 PM
bgilbert's Avatar
The 'sticky' ontop the 1st gen forum page: Tech articles, Misc part numbers: https://www.dieseltruckresource.com/...n&onlynewfaq=1
Throttle Bellcrank Bushings
These are the replacement bushings for the throttle bellcrank. If your bellcrank has alot of play, these will fix the problem.
Dodge Part# 4425053 Retail for $1.95 each. You will need two.
Old Jul 21, 2006 | 06:22 PM
Flake's Avatar
Thanks, but that's not what I'm looking for, I already have the bushings, I need the bellcrank itself.
Old Jul 21, 2006 | 06:42 PM
I'm sure your Dodge dealer can find you a part number, but I doubt it's still available. Your best bet is probably to weld it up and turn it back down.
Old Jul 21, 2006 | 08:39 PM
Flake's Avatar
I haven't had much luck with dealership parts departments lately, I'll probably end up just fixing it myself like you said.
Old Jul 22, 2006 | 09:50 AM
goodtyms's Avatar
...Throttle Bellcrank Bushings
Just for the others that might like the Cummins P/N's: 3914353
Old Jul 22, 2006 | 05:21 PM
ChrisLib's Avatar
I refurbished mine using a piece of straight aluminum tubing. The bellcrank shaft on my truck was pretty worn where it rode against the plastic bushings. It took me the better part of a day to get it clearanced right but it works nice/no play. The upside is that now instead of the bellcrank shaft riding on those two small areas where the plastic bushings are, it rides on the entire length of the shaft, hopefully this will prevent future wear. Best part is it cost nothing, I rummaged thru my "junk box" for the alm tubing.
Onemoparnut
Aug 19, 2013 08:11 PM
apwatson50
Mar 13, 2009 06:32 PM
CamaroZ
Jan 30, 2009 02:27 PM
77machomopar
Jan 24, 2008 05:30 AM
wannadiesel
Jan 28, 2006 09:51 AM
