third gear is no more.
lost 3rd in the rag yesterday . can get 1,2,4,5,R. shift into 3rd and nothing, pull shifter back to nuetral and the truck is in 3rd. hoping it is rail or fork problem. ( dont want to take apart the main shaft again).
any ideas?
any ideas?
You will have to at least pull the top and if You cant remove the tunnel from top then You will just have to pull the transmission.
Something wrong with the 3-4 syncro, fortunately if it is the ball bearings and springs inside there are kits to service them that are very affordable. First thing when You pull the transmission I would check for play on the input then start taking it apart. If it isn't the syncro then something moved on the mainshaft.
I know how it feels, I just finished putting mine back together. Rebuilding the getrag is not as hard and aggravating as putting it back on the truck and the getrag is easier to work on than other transmissions.
Hope it is an easy fix.
i didnt want to pull the trans
. soo i made a panel in the floor . turns out the roll pin on the 3-4 shift fork came out . all back together now . this was the best case senario by far
. back on the road!!
This same thing may have happened to my 89 today. Is that all pretty straight forward work once you get in there? I mean working on the forks.
I don't tend to get into my tranny at all, but it would beat 2500+ for a new tranny and all the rif raf and such.
Thanks much!
Thanks much!
once you get the top off it will very easy to tel what happened.
on mine the roll pin came loose and fell to the bottom of the housing , without getting caught up in any gears. not a hard fix by any means
onesourceoil
Feb 4, 2005 08:02 AM
tool
Feb 26, 2004 02:30 PM
