Thinking about 14cm non/wg housing for better around town and highway?????
Old Jan 9, 2008 | 12:23 AM
Rampage1967's Avatar
I have a W250 (4x4) with A518, stock converter, 3.55 gears & a 14 cm gated housing, mine runs around 4 psi boost at 75 mph. Mileage is 16 - 17 in town, 18 - 19 on highway (75 mph). Peak boost is around 24 psi.
Old Jan 9, 2008 | 06:31 PM
dbrick's Avatar
Question
Originally Posted by MikeThomas
Nope, the opposite....You will enjoy it. It brought back the low end grunt after adding my 35"s.
I installed a sps phatshaft 62/12 with a 12cm hsg. I was talked out of a 14 because the 14 would be laggier on the bottom end. I would assume it would be the same on the oem. With the 14 on the oem all your doing is increasing housing size which would seem to help your egts and top end. I'm confused
Old Jan 10, 2008 | 12:49 AM
GLHS's Avatar
Yes a 12 will spool quicker than a 14 housing..............99% of the time. It didn't on my truck. I loved my 14 housing for my hx-35.
If you plan on keeping stock injectors you will be fine with a cheap non-gated 14. You don't need/want to bleed off extra boost until you get up around 35+ psi using a 14 housing. In fact my truck ran cooler with the wastegate actuator blocked. I ran it that way until the day I sold it making 38psi.
Old Feb 22, 2008 | 12:16 AM
Alwaysworking's Avatar
alwaysonDTR
I ran around 5 psi with my 16 with 4inch straight pipe
Old Feb 28, 2008 | 10:04 PM
alwaysonDTR
and now I am running a 14 non gated with the stock non intercooled H1C and run 10 psi at 65 mph. it spools a lot faster than my 16 did with the same peak boost, the 14 just gets there faster.
Old Feb 28, 2008 | 11:13 PM
whereswaldo250's Avatar
I don't mean to hijack, but what housing would be the best for a 5 speed and 4:10's, with city and highway in mind?
Thanks
Old Feb 29, 2008 | 07:48 AM
pwrtripls1's Avatar
Thanks
Definatly a 12cm gated housing for what you have. Engine RPM has nothing to do with turbo spool, it goes by engine load. With low 4.10 gearing you are taking away alot of the engine load so the 12 would be ideal.
I ended up with a $70 12cm wg housing and it is awesome. Boost set at 32psi and gets there quick. EGT stays around 1000* in 1st through 4th gear, but in 5th gear it climbs to 1200* by 85mph and will get to 1400* at 100mph+. I want to get the bigger intercooler in and see if it cools down some.
Old Feb 29, 2008 | 08:35 PM
Really, that is sweet I had thought that it was dependent on engine rpm. Well That is a good piece of information. The 4:10's are a curse and yet a blessing
jrussell
Jun 19, 2006 05:33 PM
jrussell
Jun 14, 2006 11:04 PM
ellerman
Mar 23, 2006 12:43 PM
Mcmopar
18
Jan 5, 2005 07:15 PM
james
Feb 28, 2003 09:40 PM
