Is this theright Royal Purple for the Getrag?
Old Mar 15, 2015 | 08:13 PM
mknittle's Avatar
Is this the right Royal Purple for the Getrag?
HPS - High Performance Street Motor Oil | Royal Purple
In 5w-30
Old Mar 15, 2015 | 08:39 PM
I have used that same Royal purple oil, and I have also used Mobil One 5W-30 for a few 'Rag oil changes as it was on sale.
Old Mar 15, 2015 | 08:45 PM
mknittle's Avatar
Thanks Oliver, do you have a prefreance?
Old Mar 15, 2015 | 08:55 PM
I was happy with the shifting using both options.
Did you ever work out some/what PTO coolers you are going to use?.
Old Mar 16, 2015 | 08:11 AM
mknittle's Avatar
I got sidetracked on the coolers. There are a few things that are going to have to wait until after I get this thing rolling.
Old Mar 16, 2015 | 10:58 AM
If you wait till later, it will motivate you to change the 5W-30 as your installing the PTO covers coolers.
Old Mar 16, 2015 | 11:38 AM
mknittle's Avatar
very true.
It needs to be changed now because it has gear oil in it.I think my dad did that though so it probably has just been run around the yard a couple times.
Old Mar 16, 2015 | 11:44 AM
I have had a lot of people bad mouth the Getrag when we are talking Cummins trucks.
I usually ask them what sort of fluid they run in it.
Gear oil is the pretty common answer…no wonder why they are having lubrication issues in their 'Rag.
Old Mar 16, 2015 | 03:03 PM
mknittle's Avatar
I see some guys putting out some pretty high horsepower/torque numbers through Getrags..They don't seem to complain much.
Old Mar 17, 2015 | 09:13 PM
PapeCAT's Avatar
I just put 6 quarts of that Royal Purple 5w30 in the getrag with oil coolers last week. Then found out the tailshaft housing has a bit of a weep. Should've resealed the 'rag I guess. Too unnerving to pull it again to seal it up properly.
Old Mar 17, 2015 | 09:33 PM
mknittle's Avatar
Aww man always something. That stuff isn't cheap either.
Old Mar 18, 2015 | 03:17 AM
u2slow's Avatar
I'm using 5w50 full synthetic motor oil on two of my Getrags. I like how it shifts and no problems. $32 for a 5L jug when its on sale.
Old Mar 18, 2015 | 06:56 AM
1972RedNeck's Avatar
I use tractor transmission fluid.
Roperteacher
Jul 15, 2007 07:11 PM
Mark Thomas
Jul 10, 2003 09:07 PM
CandSRanch
Feb 6, 2003 07:01 AM
ozzie
Jan 28, 2003 09:35 AM
