Bolt-in crossover kit
Old Mar 15, 2015 | 08:21 PM
91Hoopty's Avatar
Getting ready to do redo my steering to crossover and was curious what luck you guys have had with pre-fabbed kits. I know there is a few choices out their
and just hoping for some user feedback.
Old Mar 15, 2015 | 09:22 PM
RamGuy84's Avatar
The already made up kit's are easy to bolt in and go. They come with everything needed. What I would do is take the Cover from Pass. side and bolt it onto the driver's side so you don't have to cut the arm off . and it still hold's the spring in place Without a Problem .
Old Mar 16, 2015 | 09:44 AM
BILTIT's Avatar
With a 4" lift you should be able to use anyones kit, bolt-in.
offroaddesign is really good quality.
Old Mar 17, 2015 | 07:43 PM
ricky0677's Avatar
Lifted?
I am really interested in a crossover steering but don't really want to buy a ladder to get in and out (59 age). I have 2 92 W250's and 1 D250 (all Cummins). Do you know if any will fit non-lifted or have you lifted yours already? These trucks are very high from factory. Just for clarity, I know the W's are the only ones that need crossover steering added.
Old Mar 17, 2015 | 10:47 PM
RamGuy84's Avatar
You can do it with a 2 in lift BILTIT. has done it I believe .
Old Mar 17, 2015 | 10:53 PM
BILTIT's Avatar
Yes I have crossover with 2" lift. 2" is the minimum required in my opinion, it is a very tight fit.
My crossover thread is in the sticky.
Old Mar 18, 2015 | 06:29 AM
ricky0677's Avatar
Thanks
Thanks BILTIT. 2" might not be so bad.
Old Mar 18, 2015 | 08:26 AM
mknittle's Avatar
This is what I am doing.
https://www.dieseltruckresource.com/...y-92-a-301769/
It is a bolt on and you don't need a lift or to box the frame like you would with a crossover.
FordTrax
Apr 18, 2014 08:47 PM
tritont
25
Apr 11, 2007 10:50 AM
gstelma
24
Dec 28, 2006 07:09 PM
ramcummins
Apr 30, 2004 08:15 PM
