Is their a way to add Cruse control to a 1 gen?
Old Sep 2, 2008 | 09:46 AM
jesussaves's Avatar
I have a 93 D250 without cruise control and i would like to add a aftermarket kit to it but the Audivox ones say they wont work for our trucks? anybody ever add cruise control?
Old Sep 2, 2008 | 10:37 AM
The reason most cruise control units say "not for diesels" is because diesels dont create vacuum to run the cruise servo.. HOwever, our trucks have a vacuum pump that you would just have to ''T'' into to get some vacuum for the aftermarket cruise. Almost any aftermarket cruise setup will work.
Old Sep 2, 2008 | 12:16 PM
schamran's Avatar
Cruise
I HAVE aftermarket cruise on my 1st gen. I'm not sure what brand it is, but it worked well for years, until the other day, haven't diagnosed the problem yet.... If you can find factory cruise from another truck it might be a better deal. It could just be our trucks, but (five speed) I have to rev the engine slightly before touching the brakes to turn the cruise off, and it is (adjustable) either not responsive enough, or too responsive, where you feel all the slack in the drivetrain slapping back and forth.
Just my two cents worth.
Old Sep 2, 2008 | 05:03 PM
olddodgetrucks's Avatar
gasser one could be fitted
Old Sep 2, 2008 | 09:27 PM
Rampage1967's Avatar
Why not hit the pick-n-pull & just bolt a stock system on??
should bolt right on & plug right in.
More than likely, gasser servo & switches will work.
oldblues
Aug 4, 2007 11:17 PM
Evertight
Feb 19, 2007 11:57 PM
alborada
Jul 22, 2006 12:20 AM
xyzer
Apr 23, 2005 01:06 AM
