Tach Install
Old May 3, 2007 | 07:53 PM
taterfarm's Avatar
My tach reads fine, about 800ish at idle and will hit 2600ish with stock settings. It's a cheap thing I had, all it says is supertach II and is on the 4-cylinder setting.
Only complaint is that the guage goes to 8 grand so i will never get to use the top half.
would the stock sensor on your truck need to be repositioned or respaced?
Old May 3, 2007 | 08:17 PM
GasganoFJ60's Avatar
Ok, last dumb question and this should solve all my problems. I was planning on getting an Isspro Tach along with the Isspro wire harness for the Dodge CTD, but, the picture of the wire harness looks just like a bunch of wires with no kind of fuses or regulators or anything like that. Could I just save myself $40+ bucks and buy wires and make the harness myself?
Here is that wire harness...
http://www.isspro.com/proddetail.php?prod=R8912-92
Also, what tach would ya'll recommend?
Old May 4, 2007 | 10:39 AM
ofcmarc's Avatar
I was thinking about checking that. We'll see.
Old May 5, 2007 | 11:54 AM
ofcmarc's Avatar
I had a thought in the wee hours of the morning. Some where in my searching of the archives someone said that when they installed a dealer option tach in a pre-cranksensor 1st gen that they had to glue a (I'm translating that to 1) magnet to the crank pulley. Based on this, I wonder if the tach signal in the factory harness is a 1 pulse per rev signal. This would explain the approx. 1/2 rpm reading that seems to happen.
Perhaps a second magnet on the pully might make it work. Any thoughts??
Old May 5, 2007 | 12:10 PM
Ace's Avatar
Ace
My ISSPRO crank sensor uses two magnets.
Old May 5, 2007 | 01:04 PM
Short Box's Avatar
That is good to know, I also have an old SUN supertachII,which I may put in now. The one that is in now is only 2 inches and is hard to see.That would also free a a place for a fuel pressure gauge.
Old May 6, 2007 | 10:57 PM
apprentice's Avatar
so nobody else has a tach installed or has mounted one that works without having to put a second magnetic pickup on the crank?
Old May 7, 2007 | 12:12 AM
MrExtreme's Avatar
Tach installed
I just installed a cheap Sun tack off of the mentioned 4 pin connector, I think the 4 cylinder setting is pretty close, on the mat, maxxed out it reads about 2900-3000. My engine also seems to idle high and the tach reads 8 or 9 hundred, it all seems about right to me.
X
Old Jun 18, 2007 | 09:52 PM
Power Ram 250 C's Avatar
I am going to install a isspro tach by using the isspro sensor kit with the two magnets. My dodge is a 92 with the computer but I think my computer is junk so I bought the complete kit and am going to install it. Anyone else ever done this? If so any help on installing would be a help. Still waiting on the sensor for now.
Old Jun 18, 2007 | 10:24 PM
92DuallyCTD's Avatar
Yeah, I bought a new Isspro tach off ebay w/Isspro Dodge Ram harness(the aforementioned R8912-92) and simply plugged it straight in according to supplied directions(and verified by the ever-helpful sticky's here). It worked accurately from the get-go, but it was a diesel-specific tach(R-8503 I think?). The 92 crank to my understanding has only 1 notch for the sensor, so as you speculated with a tach set to 4cyl, an opposing magnet would be needed. Here is a link to Isspro's installation sheet that may help explain the sensor requirements/installation. Good luck! http://www.isspro.com/installation/IS236A.pdf
Old Jun 19, 2007 | 09:52 AM
gomerpile's Avatar
no i just installed a sunpro tach set to 4cyl that works just plugged into the factory harness. nothing else required. goes from a bout 750 in drive to 2700 in first gear to the floor
Old Aug 8, 2007 | 02:22 PM
ofcmarc's Avatar
I finally got around to geting a picture of my tach as installed. I think it looks good. It still runs at about 1/2 speed but I will live with that until I have more time and the more important projects I have are taken care of.
Cummins610
May 7, 2008 07:53 PM
rbrettctd
May 2, 2008 07:13 PM
Layton
Feb 18, 2007 06:33 PM
'80Toad
Apr 10, 2005 03:47 PM
boiler-rat
Apr 1, 2005 05:58 PM
