Tach install question
Old Mar 27, 2005 | 09:51 AM
boiler-rat's Avatar
My dad recently gave me an Isspro 600 293 Tach kit. Everything is there but the magnets. The instruction sheet that came with it says install the magnets with the blue side out. I have some little magnets I can use but does anyone know how the polarity on the magnets go? I'm sure that is what corresponds to the "blue" side the instructions speak of.
Old Mar 27, 2005 | 02:45 PM
edwinsmith's Avatar
I don't think it matters what the polarity is. It just produces a pulse in probably a hall effect pickup. A hall effect pickup changes it's resistance in the presence of a magnetic field irregardless of the polarity.
Edwin
Old Mar 27, 2005 | 11:42 PM
ares's Avatar
your truck should have a crank sensor stock and all you have to do is plugin to the harness under the dash.
ill take that mag pickup kit off your hands.
Old Mar 30, 2005 | 07:49 PM
boiler-rat's Avatar
So I should just be able to hook my tach into the plug under the dash? What kind of plug am I looking for? Anyone else have any input on this?
Old Mar 31, 2005 | 01:14 PM
Nuttymopar's Avatar
My plug was located right under the steering column location, slighty to the right. It has 4 wires (I think) into it and my tach had just little plugs. I connected them to the truck's plug one by one and haven't had a problem in 2 years. Tach didn't have any real plug on it, just loose wires with plugged ends.
Old Mar 31, 2005 | 02:10 PM
1st gen Hobie's Avatar
I have a connecter with 4 wires going into it and the other side has to connectors for something to plug into. Is this it?
Old Mar 31, 2005 | 02:13 PM
Nuttymopar's Avatar
Very possibly. Not looking at my truck currently. Sorry.
Old Mar 31, 2005 | 08:05 PM
ChrisLib's Avatar
It`s a flat 4 pin connector, to the left of the column on my truck. IIRC the wire colors are white,orange,black,black...I could be wrong tho, havta go and look at it to be 100% sure.
Old Apr 1, 2005 | 05:58 PM
boiler-rat's Avatar
Thanks for the info. I was just looking at a list of pcm pin locations that I copied and printed from this site and it says #43 Gray/light blue Tachometer provisions. Something else that might come in handy.
Cummins610
May 7, 2008 07:53 PM
rbrettctd
May 2, 2008 07:13 PM
ofcmarc
Aug 8, 2007 02:22 PM
Layton
Feb 18, 2007 06:33 PM
'80Toad
Apr 10, 2005 03:47 PM
