tach install
Old Feb 18, 2007 | 01:46 PM
Layton's Avatar
A few questions
Hi guys I have read throught the forums and have some questions.
1 i would like to hook up a tach to my truck, it is a 92 with 5 spd, i understand there is a factory wiring harness available but I was wondering if my old tach for a gasser would work.
2 i have read that there is a lubrication problem with the 5 spd and was wondering if this is why my synchros feel stiff and like to almost grind a little when shifting.
3 Another thing I almost forgot, the guy i bought this thing from put new 16" rims on and big mudder tires and now the speedo is out by about 10-15kmh/hour, what can be done to retune the speedo is it a gear on the transmission somewhere or is it electronic.
Other than that this new purchase seems to be okay, oh yeah except I just did my first fuel mileage check and it seems around 14mpg which is about 6 less than I had hoped.
Thanks
Old Feb 18, 2007 | 06:09 PM
Layton's Avatar
I know that the tach issue is all but beat to death but any other thoughts on my questions. thanks.
Old Feb 18, 2007 | 06:33 PM
Isspro makes a plug-in tach. Autometer has an alternator tach that works well. Some guys have had good results with a cheapo gasser tach set on 4 cylinder, if you have one laying around it's worth a try.
A lot of uninformed people put gear lube in Getrags. This makes them shift terrible until they get good and hot. Try some synthetic 5W-30, or a dedicated trans lube like Royal Purple Synchromax or Redline MTL.
The speedo is electronic, there are converter boxes you can use to correct the signal from the VSS.
Cummins610
May 7, 2008 07:53 PM
rbrettctd
May 2, 2008 07:13 PM
ofcmarc
Aug 8, 2007 02:22 PM
'80Toad
Apr 10, 2005 03:47 PM
boiler-rat
Apr 1, 2005 05:58 PM
