switching 727 to A518
Old Jun 3, 2007 | 06:24 PM
Cowboy_Customs's Avatar
That should be pretty straight forward right? hmmm maybe not. Any one done it before? Id throw a floor shifter in.
Old Jun 3, 2007 | 06:40 PM
rbrettctd's Avatar
The computer system would throw you off. Lots of wires, plus an entire pcm for it. Im bout to throw a Getrag in mine.
Old Jun 3, 2007 | 07:29 PM
rovingbenz's Avatar
I thought the module just controls the overdrive. A switch on the dash could handle that from what I've read here. You do have a crossmember and drive shafts to deal with though.
Ryan
Old Jun 3, 2007 | 07:43 PM
rbrettctd's Avatar
Oh okay. Are the crossmembers different?
Old Jun 3, 2007 | 07:50 PM
rovingbenz's Avatar
I don't think the crossmember is different but it sure appears to be farther back on the 518.I'm sure somebody will chime in that knows.
Ryan
Old Jun 3, 2007 | 08:06 PM
Fred Swanson's Avatar
If anything, you may just need the trans mount from the 518 along with the tranny.
Old Jun 3, 2007 | 08:15 PM
Hmmm... thatd be cool, a switch to control overdrive. Im sure something could be rigged up, no need for a temp switch to diddle with. Im really curious about this now. If some one could measure tranny length, n compare cross members thatd help a lot. Heck I bet a conversion like that would be very popular. Maybe even a sticky! lol
Old Jun 3, 2007 | 09:45 PM
Boatnik's Avatar
This is my second try for a post on this thread. My computer or my computer skills are lacking.
When I upgraded the TC, flexplate and valve body, it was suggested to me by Tim to upgrade to a 47rh. They handle more torque than a A518 and you have the advantage of a lockup. I was stubborn and cheap so I stayed with mine. The A518 is longer than the 727. The od unit was added between the tailshaft housing and the tranny. It is actuated by a solenoid valve in the valve body which is switched on the ground side by the PCM. We had a little trouble with mine when we did the valve body so I put a switch in the cab to make it work until I could get it in the shop again to fix the wire. It worked just fine manually. The o/d cannot be engaged unless the tranny is in third. Something about the way fluid is channeled thru the tranny.
Old Jun 3, 2007 | 09:46 PM
sdstriper's Avatar
I would do the shifter OD button from a 94'-up and not worry too much about it. The only real challenge would be if it was an early 2wd, the tunnel is smaller. Compare one to a 4wd trans tunnel some time you'll see what I mean. If I am not mistaken the later trucks (91.5'-93') came with the larger square 4wd tunnel.
Old Jun 3, 2007 | 10:15 PM
scottmn1's Avatar
I've done it........I took out a Getrag and put in a 518...I wanted and exhaust brake so I then took out the 518 and put in a 47RH. You just need one simple switch to send a ground signal to the o/drive solenoid to turn it on when you want it on the 518. You will need 2 on a 47RH(one for overdrive, and another for lockup. If you are contemplating a 518, by all means I recommend the 47RH!!!! The lockup torque convertor is far superior than a non lockup tranny.
93Fury
Mar 31, 2010 01:33 PM
WhiteBeast92
Sep 17, 2009 07:41 AM
smoking
May 1, 2009 06:14 PM
Alwaysworking
May 11, 2008 03:41 PM
bhoff1175
May 9, 2006 07:25 PM
