Striped my air bleed banjo bolt
Well, of course that skinny little return-line is still intact, but it never gets messed with anyway.
The flexible lines make life a WHOLE lot easier.
No longer is it a fight to remove the lift-pump.
http://www.discounthydraulichose.com...ons_p/2403.htm
The fittings at the injector-pump and both sides of the filter are 12MMx 1.5.
The top fitting on the lift-pump is 14MMx 1.5 and the lower fitting is 1/4-NPT.
I use 06-JIC = 3/8.
The big line kit would be awesome i wish i would have known about it before i got the new steel line for the piston pump.
Do you think the oversize banjo fittings will make a difference with the steel lines?
dslpwr81
Mar 10, 2008 09:05 PM
Bad Ramer Jamer
13
Jan 12, 2008 05:38 AM
aicomp
Nov 6, 2006 01:03 PM
The return lines are perfectly adequate as is, though.
