Still smoking Mega
Still smoking Mega
As per my previous post, Starting hard and smoking clouds of white continues until the engine comes up to operating temp. Then it runs clear and starts normally for the day. The shop it went into could find no air leaks or other problems. From what I can tell it has to be the injectors sticking or leaking. I see some performance injectors from Pensacola Diesel for $229 for a new set of 6. They claim 25 to 40 hp increase. I wondered if anyone has had any experience with these. The injector pump I purchased from them has been fine. I have asked for more specs on the injectors and will post when I hear more.
I have my truck plugged in, even down here on the coast. I have it on a timer that comes on 2 hours before I know I have to leave in the morning. truck fires right up, with little or no grid heater action.
I'm hopefully going to get my new injectors in on thursday, and hope that cures my smoking problem as well.
Hi 9mm I am north of Powell River, the temp is just above 0*C. I would plug it in but it lives in a parking lot at the end of the road til I come in by boat.
I'm looking forward to TC changing his injectors as his problem sounded
similar.
I did some checking on Pensacola Fuel Injection and there is a lot of unhappy customers. I may be suspecting my new pumps cold start advance.
similar.
Finally everything is great. The problem was that the pump I recieved was for an intercooled engine and of course mine is non I/C. I am amazed that it started at all. After changing back to the non I/C pump which just needed the fuel screw turned in a couple more turns I am a happy trucker. Now I know the non I/C pump is a little longer overall than the I/C and of course the cold start mechanism is powered in the first case and not in the second. Pump is turned up and timing advanced slightly and with the 366 spring it really pulls like a different beast. Happy, happy, happy!
I will be listing the rebuilt injector pump for 91.5 and later I/C engine in the classifieds.
Well good to hear you got it all figured out. The IC IP have smaller delivery valves compared to the Non-IC units. So maybe you were not getting enough fuel to your injectors...why that would cause heap big smoke I'm unsure of. Also the Non-IC KSB is powered differently then the IC ones.
Hi TC, My info is that it was the KSB. In the non IC it is powered when running and the opposite with the IC or visa versa. It is amazing that it started at all but it did. Just clouds of smoke and rough running til it got to operating temp and then ran great all day. Live and learn. I shouldn't have to touch it for a long time now, just going to enjoy it.
zookeeper
Aug 13, 2011 12:08 PM
NotEnufGarage
Jun 1, 2009 10:46 PM
Evil Genius
Jun 15, 2008 05:42 PM
abc4yew
Mar 29, 2008 08:37 AM
Tiara3100
29
Sep 5, 2007 10:49 PM
