Still playing with pump adjustments
Old Sep 14, 2004 | 10:48 PM
DJ's Avatar
DJ
I've finally got my pump adjusted pretty good, I have power from the get go but I still get a lot of smoke in third gear on a heavy pull foot to the floor from about 2000rpm 18psi up to governed speed. Even at 26psi just before it defuels it smokes a lot. I don't want to lose anything on the low end so what do I adjust next. I've got the afc on max, the star wheel out 6 turns and I've backed the full fuel screw out 5/8 ths of a turn so far. I'm thinking if I back the full fuel screw out a little more it should do it. If I back off on the afc it will affect low and midrange. I've still got the stock exhaust and intake system and I suppose spending $500 to upgrade would get rid of the smoke but I want to spend my money on a repaint. Think putting the 16 housing back on would make a difference?
Old Sep 14, 2004 | 10:50 PM
jiMMyCTD's Avatar
im new to these but mine doesnt smoke at all hardly(havent loaded the trailer yet). but i would think the 12 is choking on the top end and a 16 and some big exhaust and and air in would be ideal!
jiMMy
Old Sep 15, 2004 | 05:28 PM
You don't need less fuel, you need more air! You're only making 26 psi with a 12 cm housing? You must be running the stock wastegate actuator then? Either get/make a boost elbow (a calibrated leak in the boost line to the actuator) or a TurboMaster to crank the boost up to 35 psi or so, that should clean things up nicely. I've got my TurboMaster set to open at 30 psi.
bnrealfast0
Oct 10, 2007 10:21 AM
bhoff1175
Aug 20, 2006 11:58 PM
Ocmechanx
Mar 30, 2006 06:51 PM
eng208
Aug 24, 2005 07:31 PM
apache
Mar 11, 2004 11:34 AM
