Starter Relay
Old Jan 18, 2006 | 03:22 PM
kc8ksg's Avatar
Starter Relay
I haven't looked to see where it is yet, but I was wondering where the starter relay was located on my truck. A few times I have tried to start it the starter hasn't engaged, so I am pretty sure it is either the starter relay or in the ignition switch. I'd like to find the relay to see if it needs cleaned, or incase it is in the ignition switch so I can still get it started and not be stranded.
Thanks
Chris
Old Jan 18, 2006 | 03:34 PM
It's mounted on the driver's side fender. It's a standard Bosch-type relay, they are usually under $10.
Old Jan 18, 2006 | 03:39 PM
kc8ksg's Avatar
okay thanks for the quick reply, shouldn't be to hard of a fix, I'll clean it up and hopefully that will fix it.
Chris
Old Jan 18, 2006 | 07:04 PM
EClancy's Avatar
I bought a "auxiliary light relay" from advance auto parts, going to use it for some lights on a jeep. I went to start my cummins one day, and i had nothing. Looked under the hood, and someone had cut the relay out of my truck..either lucky guess on which one, or they just cut something to mess with me. Anyways, i used my headlight relay, works good as new. Cost 2.89, and it is located on the drivers fender, can't miss it.
banzaitoyota
Jan 26, 2022 06:20 AM
FMB
Nov 14, 2010 09:09 PM
Remnik
Aug 7, 2007 02:27 PM
ouchman
Apr 8, 2006 07:20 PM
mazeppa
Feb 10, 2004 06:54 PM
