Started cutting for Mega Crew Cab.
Old Sep 1, 2009 | 08:21 PM
  #46
ADMOPARMAN's Avatar
Well looking at the roofs..... they stamped the Club cabs inner roof out of one piece so there is no pinch weld to but up to.
But the pillars line up right.
Old Sep 2, 2009 | 01:25 AM
  #47
95ram's Avatar
Originally Posted by Trebor
ADMOPARMAN did you have any difficulty in removing the rear leaf springs?
When I did mine the other day I had to BEAT the rear spring hanger bolt out with a 15lb sledge. I have a very trusting wife. She held the punch while I wacked away on it.
Old Sep 4, 2009 | 08:08 PM
  #48
Greg82's Avatar
Very nice work so far. I look forward to watching it all go back together.
Old Sep 4, 2009 | 08:09 PM
  #49
ebteckx's Avatar
I cant wait to see this beast assembled. Looks great so far!!
Old Sep 5, 2009 | 08:05 AM
  #50
CaptainChrysler's Avatar
Looks like quite a project. Should be sweet when it's done!
Here is a little trick I found for removing spring bolts: Be fore you do anything soak it good with WD-40. Then put a breaker bar on the bolt head,and try to tighten it. This will break the bolt free of the steel sleeve in the bushing, while it is till clamped tight enough so that it does not try to spin in the bushing. If you loosen the bolt first, the sleeve usually just spins inside the rubber. There are little ridges on the ends of the bushing sleeve, once you spin it much these get chewed off and then they can be a PITA.
Old Sep 27, 2009 | 05:36 PM
  #51
ADMOPARMAN's Avatar
What is this?? A W250 camper Chassis??
FINALLY got the Club Cab cut up and into the garage, I had to fight the box getting it off. Whoever put this thing together decided to sandwich the gooseneck mounting to the box then weld it together... Just wanted to get this far by winter so I have something to work on when the weather is cold.
See, the doors will fit!!
Old Sep 27, 2009 | 06:43 PM
  #52
NO_SPRK's Avatar
Sweet. Tons of leg room.
Old Sep 27, 2009 | 08:50 PM
  #53
Awesome , its lookin good
someone did this build before and i don't know who! but i've seen pics of it!
EDIT- found it
gonna look awesome.
Did you every look at that cummins donor truck you found?? the one with the NV4500 and banks kit... someone give this man a cummins before he puts a 318 in there !!
Old Sep 27, 2009 | 09:05 PM
  #54
ADMOPARMAN's Avatar
EDIT- found it
gonna look awesome.
I've inquired about that truck several times... There has to be more pics of it out there somewhere....
He sold that truck before I could make the drive to go see it.
And its my 2nd crew that will most likely get the gas engine... That will be a daily driver till the other truck is ready.
Old Dec 6, 2009 | 12:16 PM
  #55
ADMOPARMAN's Avatar
They came together!
Got the front and rear parts together! It is still quite rough but I was just checking fitment.
Old Dec 6, 2009 | 01:43 PM
  #56
jesussaves's Avatar
just curious, do most people swap a cummins into the crew cabs or do they swap cabs onto the cummins frame
Old Dec 6, 2009 | 01:46 PM
  #57
ADMOPARMAN's Avatar
Crew cabs only fit on (unmodified) crew frames.... The kick up in the frame prevents the crew cab from sitting on other types of frames. So I would say MOST people put the Cummins in a crew cab/frame.
Old Dec 6, 2009 | 04:11 PM
  #58
crewctd's Avatar
Looking good !
What bed are you going to run?
Old Dec 6, 2009 | 04:22 PM
  #59
ADMOPARMAN's Avatar
Originally Posted by crewctd
Looking good !
Long box frame so a short box will fit perfectly with the added cab length.
Old Dec 6, 2009 | 06:00 PM
  #60
Sweet looking
