stacks
dont like em much. probbaly cuz i live in the city, but do like other truck with them that puff that smoke he he.
i want to make 4inch pipe come ou in front of the passenger rear wheel. he he. LOUD!
jiMMy
jiMMy
I like the look, but am weighing the lost bed space, clearance issues, and noise! I live in a funny neighborhood. My truck is essentially stock and will be for a while longer, so smoking isn't a concern. What do you all like better: Mitre'd, Turn out's, or square tops? I like both the square tube cross pipes and the round tubes, but price will probably help determine which I use.
Just a thought: If you ran an auxillary fuel tank in the bed, notched around the exhaust piping (with proper clearances, of course) you would have a very nicely heated winter tank!
I love the way stacks look. I think turnouts look best on a 1st gen, and I like mitres on the newer trucks. Here's why I don't have stacks: On extended cab 1st gens there's a crossmember right where you would want to come up into the bed with the exhaust.
This means you have to go further back, so instead of losing 6-8" of bed space you lose like a foot and a half. You can go under the frame and come up out by the side of the bed, but my truck is a 2wd so ground clearance is an issue. So I went with 4" exhaust instead.
Im thinking of running 4 inch to a y the splitting to 3 inch stacks,,first because take up less room,,should be no restriction as 2 -3 inch pipes are bigger than a 4 inch and last,the 4 inch almost seems to big,,,and i like the turn outs better as well
I think stacks only look good on duallies. But there's a few SRW trucks out there with the right hardware (bumpers, grille guards headache racks) that look good with stacks.
Here's my friend Kevan's CC 4x4 12v Dually with a 5" single stack. The duals looked a bit too much, so he went with the single outlet. I think it looks PERFECT on his truck.
It's also 5" from the turbo (HX40) back, so it sounds insane.
I cut right through the bed cross member on my 99 and my sons 94.
https://www.dieseltruckresource.com/...cat/500/page/1
I don't worry about bed space since I rarely haul anything in the bed anyway.
Originally posted by Dieseldude4x4
Are you talking about a frame cross member or the cross member that is sheet metal as part of the bed?
nfsommer
21
Apr 4, 2007 03:45 PM
rockittboy
Feb 3, 2006 12:38 AM
