Spring and gauges are in but not running
Old Jan 12, 2011 | 07:39 PM
BCRick's Avatar
Unhappy Spring and gauges are in but not running
Had a great couple of days putting in my new pillar pod, pyro, boost, and fuel pressure gauge. Hooked everything back up and all was good. Started and ran fine.
Next I started on the VE spring install and all was by the book. I did notice that my '89 has no plastic washer between the throttle shaft arm and linkage plate. Didn't seem to be missing but?
Getting the allen screw on the back of the pump is a piece of cake with a long ball head allen wrench. Also there is a spring installation tool for radio control airplanes that made the spring really easy. All went back together ok, no other changes to settings. Now no go.
It fires like normal for the first second and then just cranks. Tried it multiple times but it won't continue. I'm close to positive it is indexed right. I'm going to take it apart again tomorrow and see if I can see anything but thought I'd ask for feedback since it's too dark tonight.
Old Jan 12, 2011 | 09:49 PM
92smokin blacky's Avatar
will it start and run if you give it a little throttle? if it does, then i bet its the throtle indexing. I'd say check your indexing again.
Old Jan 12, 2011 | 10:27 PM
Rickcher's Avatar
Ditto. Loosen the throttle shaft and move it counter-clockwise a notch at a time. Mine didn't go back exactly where it was originally.
Old Jan 12, 2011 | 11:12 PM
BCRick's Avatar
Thanks for the replys, that's the only thing I can think of to try.
When I turn the key, it fires and immediatly quits firing and just cranks. Same with or without any pedal.
Is there a low pressure bleed point on the pump to make sure it's got fuel?
Kman9090
29
Dec 6, 2007 06:43 PM
Vitamin C
Mar 26, 2007 09:59 AM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
BigDan
Sep 3, 2006 11:04 PM
