Speedometer
It's on the transmission (2wd) or transfer case on the driver's side. Make sure the nut that holds it on is not loose and that the electrical connection isn't cruddy. Follow the wiring harness up under the truck and make sure it's not chafed and rubbing.
The only difference is that the vss is on the transfercase. It will be on the driver side and it has 3 wires comming out of it. It will be near the rear drive shaft output. It is not the 3 wire connector up by the shifter linkage that is the nss.
ridofpwrstroke
Mar 7, 2003 07:08 PM
