Speedo Problem
Old Jun 1, 2003 | 01:07 AM
Weg's Avatar
Weg
Speedo Problem
Hi all,<br><br>Just bought a 91 5 spd 4x4 Cummins Friday and the Speedo doesn't work, I'm not the most clueless person about working on vehicles just havn't had alot of experiance working on alot of them so anyone think they can help me?
Old Jun 1, 2003 | 05:40 PM
AlK's Avatar
AlK
Re:Speedo Problem
That is a fairly common problem on the first gen trucks. I had this happen on my truck and in most cases it involves the speed/distance sensor. The speed distance sensor on the 4x4 is mounted on the driver's side of the transfer case and on the 2wd is located on the transmission (not sure which side). This device will have an electrical connection on it. Unplug it and remove it from either the transfer case or the tranny. Take it apart, clean it and inspect it for any damage. Also clean the electrical connection and spray it with a good electrical contact spray. This may solve your problem.<br>---<br>Al
Old Jun 2, 2003 | 07:14 AM
Dieseling's Avatar
Re:Speedo Problem
You might also want to check the connections on the back of the speedometer head itself. Mine wasn't working also. I took the speedometer out of the dash, unplugged the connections, squeezed them tighter, reinstalled and it works perfectly.
Old Jun 2, 2003 | 06:05 PM
Weg's Avatar
Weg
Re:Speedo Problem
I've already taken the whole dash apart and it appears that the connections are making good contact with the speedo (pain getting it off, didn't want to let go) so i'm pretty sure it isn't that, I'm thinking its either the speed distance sensor on the Transfer Case or the speedo itself
Old Jun 3, 2003 | 01:26 AM
AlK's Avatar
AlK
Re:Speedo Problem
After you have taken care of the speed distance sensor and it is still not working then maybe a good wack on the dash with your right hand may get the speedo working again :
Old Jun 3, 2003 | 04:04 AM
Dieseling's Avatar
Re:Speedo Problem
Mine appeared to be tight also. As a last resort, I disonnected it and crimped the female connectors a little and then reinstalled. But, do as AIK suggested. While driving, hit the top of the dash hard. If the speedometer starts to work, then it's a problem with one of the connnections not making good contact. If not, then it is either the speed/distance sensor or associated wiring.
Old Jun 3, 2003 | 11:04 PM
Weg's Avatar
Weg
Re:Speedo Problem
I'm thinking its the speedo distance sensor, so i'm going to cheat and steal parts off my previous Rig i'm trying to sell to see if thats the problem (92 gasser shouldn't be anything diff speedo wise right?) but i'm pretty sure its that distance sensor, just a huntch
TJE
Mar 9, 2011 06:48 PM
DeanM
Sep 3, 2004 10:01 PM
Raspy
Mar 27, 2004 04:36 AM
97CTD
Aug 14, 2003 03:31 PM
