speedo is off... after gutbag swap
Old Dec 24, 2010 | 08:47 PM
RednekRangeR's Avatar
i picked up a getrag out of a late 1990 one ton 4x4, got it all together and running. but my speedo is 5 mph faster than my actual speed.
so say it says 40, im actually doing 35.
do i need to go get the little gear box dealy worked on by my speedo shop to make this work right?
otherwise this is one hell of a good set up, now that i got it together.
Old Dec 24, 2010 | 08:49 PM
oops sorry forgot to mention this is a 93 w250 truck that i put this pile all into
Old Dec 24, 2010 | 09:12 PM
Onemoparnut's Avatar
You probably have the wrong speedo gear in there they make a few different ones. It all depends on your rear gears and tire size as to what gear you need.
Old Dec 24, 2010 | 10:00 PM
ah, got ya.
i should be able to get away with swapping the gear from my auto 205 into the manual 205 then.
after looking at the parts manual i see how this works.
same as the fords i grew up working on....
Old Dec 24, 2010 | 11:41 PM
Originally Posted by RednekRangeR
ah, got ya.
If the speedo cable hooked up the same, then it should be a direct swap. My NV4500 reads about the same, 5-7mph faster then actual speed. I haven't opened it up to look at the gear yet, but obviously it's geared for a 4:10 axle, not a 3:54.
Old Dec 25, 2010 | 06:54 AM
Trebor's Avatar
My speedometer reads 5-7 MPH faster than my GPS. My odometer reads exactly spot on. Chrysler engineering at its finest!
Old Dec 25, 2010 | 01:43 PM
yep, speedo gear it was. 14 teeth vs 16 teeth.
all is good now... or as good as it will get.
now off to the cruise control.
i dont use it much, but i like to have it sometimes
Old Dec 25, 2010 | 06:30 PM
Trebor's Avatar
I'm betting your odometer is off now. Check it with a GPS.
Old Dec 25, 2010 | 06:37 PM
close enough for me.
i will check it when i get to go on a trip... but that will be a while.
this is my play toy now and i dont drive it much. yesterday was the first time i have drivin it in a month, after tearing the center out of my flexplate...
i still need to get my rear driveshaft back from the shop, the guy who does the work went on vacation. it will be done monday though, and i will probably pick it up then or tuesday.
sdseva
Sep 26, 2010 11:43 PM
colby1979
Oct 29, 2008 11:42 PM
1tondodge
Jul 11, 2008 11:35 PM
Mopar Kid
Mar 8, 2007 11:39 PM
Mopar Kid
Feb 26, 2006 10:19 AM
