Smoke - bump start vs starter ???
Old Sep 9, 2006 | 01:21 PM
Bill Tomlinson's Avatar
Every time I start my truck the way normal people do there is a significant puff of rich soot. I have gotten some pretty nasty looks and comments. I don't mind it when I do stuff like this deliberately but I'd like to have a choice ,
My pad behind the garage is just long enough to bump start the truck. When I do this there is NO soot. Maybe someone could explain why and perhaps there might be a fix for the soot on a normal start?
Old Sep 9, 2006 | 03:06 PM
When my starter went out and I had to bump start for a couple days, mine always smoked. I always used 3rd gear.
The reason they smoke is that there is a spring (called the starting spring) in the pump that forces the control collar to full fuel below 400 RPM. What gear are you bump starting in?
Old Sep 9, 2006 | 05:46 PM
Reverse and not a trace of smoke in the actual startup. When I drive away right away I get the usual amount of smoke you get when the engine is cold. And when I say that it smokes on a normal startup, hot or cold doesn't matter, I mean a lot of smoke. It does not last more than a second but it sure gets dark back there.
I see what you mean though about the gear, perhaps my reverse gear starts bring the rpm's up so fast that no smoke is generated.
dzl_damon
Aug 26, 2009 07:49 PM
98Ram25004x4
Jan 11, 2007 09:10 AM
royta
Nov 6, 2006 08:19 AM
LCH
Oct 26, 2006 05:10 AM
Ramtough
Jul 11, 2005 10:44 PM
