Skyjacker D200CDK or D200CDKS
Old Aug 24, 2011 | 12:04 PM
bobva's Avatar
My front springs have seen better days. The rears I don't see any problem.
From what I understand a SK D200CDK http://www.jegs.com/i/Skyjacker/825/D200CDK/10002/-1
is what I need to put new life in my front plus (((((level))))) out the truck. I believe this is the kit I could use or need.
If I was to buy this kit would I get new life in the springs and (((((UNlevel)) the truck? I would Like my truck to be level.
SK D200CDKS http://www.jegs.com/i/Skyjacker/825/D200CDKS/10002/-1
Thank you
Old Aug 30, 2011 | 05:39 PM
texsasdiesel's Avatar
if you're just looking to level the truck up, they sell just front springs. the two kits you've listed are to give your front a 2.5" lift all the way around. look at the skyjacker website and it'll explain more in detail in what is actually in those kits
James
Old Aug 30, 2011 | 11:03 PM
bobva's Avatar
James
Correct Im looking to level my truck.
Ive been all over the skyjacker site and for the life of me I cant seem to find the leveling kit or springs only for a 93 W250.
Old Aug 31, 2011 | 01:22 AM
Stude4x4's Avatar
I just bought their 1" lift springs for the front of mine and it leveled it out perfect. Part number is D100C. If you want to go more the part number is D200C for 2.5" lift.
Jake
Old Aug 31, 2011 | 09:50 AM
Jake
There you go, that's the part#'s that you need
James
Old Aug 31, 2011 | 12:29 PM
bobva's Avatar
Thank you
That 1" set also makes more sense. D100C http://www.summitracing.com/parts/SJA-D100C/
Also do I need to order the Part# D240CDA. Or any thing else. Bolts I can get local if needed.
Sorry I cant make heads or tails on internet shopping the Pic in the summit add has no bushings but the add reads Polyurethane Red
Old Aug 31, 2011 | 12:38 PM
the 240cda should include the ubolts and bushings from what i remember. I recently ordered a set from 4wheelparts.com for my crew cab build, and got the d240CDA kit from amazon for much cheaper than anywher else. my springs did not come w/ bushings, so that would be my recommendation
James
Old Aug 31, 2011 | 12:55 PM
bobva's Avatar
the 240cda should include the ubolts and bushings from what i remember. I recently ordered a set from 4wheelparts.com for my crew cab build, and got the d240CDA kit from amazon for much cheaper than anywher else. my springs did not come w/ bushings, so that would be recommendation
James
Thank You
Bob
dingo
Mar 22, 2003 01:38 AM
MARKY MARK
Mar 16, 2003 10:32 PM
MARKY MARK
Mar 2, 2003 09:12 AM
CumminFast
Jan 31, 2003 04:47 PM
MPagnucco
Oct 17, 2002 09:50 PM
