shutoff solenoid
Old Jan 17, 2009 | 06:31 PM
1985cucv's Avatar
shutoff solenoid
Ok guys it seems as though my shut off solenoid works good because i can take the wire off and it will shut off the truck however it is being stubborn and shutting off the truck when i am driving down the rough frost barren roads. I only have one wire hooked up to it and it would be the one that is pointed toward the side of the truck not the back of the truck on the solenoid. My question is do you need both of the wires hooked up? Also is there a manual shut off on these trucks? i saw the write up on the pull lever which i would like to install but i would also like to have a secondary way of shutting off the fuel flow if it can be done. If someone had a pic it would be great as the ones on the manual shutoff confuse me a little bit thanks guys
Old Jan 17, 2009 | 06:40 PM
Theres a lever on the side of the inj. pump. , thats the shutoff
Old Jan 17, 2009 | 06:43 PM
heres the picture, it was in the sticky? howd you miss it?
https://www.dieseltruckresource.com/...5&d=1216231336
Old Jan 17, 2009 | 06:48 PM
comptz's Avatar
https://www.dieseltruckresource.com/...d.php?t=211283
This is the whole thread in the sticky.
Old Jan 17, 2009 | 07:27 PM
1985cucv's Avatar
yeah i saw that alls you have to do is pull back on it and it shuts off right?
Old Jan 17, 2009 | 07:30 PM
comptz's Avatar
yes. My solenoid still works so i have not used mine.
Old Jan 17, 2009 | 07:35 PM
1985cucv's Avatar
thanks guys for the input
Old Jan 17, 2009 | 07:37 PM
comptz's Avatar
No problem.
Old Jan 17, 2009 | 07:44 PM
Replace that crappy spade terminal with a ring terminal. You have a flaky connection there now, that's what's causing the truck to shut down.
Old Jan 18, 2009 | 12:08 AM
BearKiller's Avatar
Take an 8MM wrench, remove the nut that is holding the two-bladed spade-terminal on the solenoid, cut off the female-spade-terminal from the solenoid wire, crimp and solder a ring-terminal onto the solenoid wire, put the ring-terminal over the stud on the solenoid and replace the 8MM nut.
Go ahead and fix up a kill-cable for when you "gut" the solenoid and don't have to worry with it anymore.
Old Jan 18, 2009 | 08:15 AM
BC847's Avatar
1st Generation Admin
Ummm . . . .. it's OK to have a working fuel cut-off solenoid. Don't give in to peer pressure, just say "No!" to the pull-cable.
Old Jan 18, 2009 | 10:48 AM
1985cucv's Avatar
i like the idea of the pull cable makes me feel like im driving an old time rig
Old Jan 18, 2009 | 11:31 AM
Its good to have a pull cable even on a stock truck, never know when that thing may stop working.
However 5 clothes hangers put together running through the cab with a ball of duct tape on the end as a handle is unacceptable
adamroofer25
Jun 24, 2004 05:54 PM
Palmetto_kid
15
Nov 17, 2003 02:47 PM
NOTSTK
Oct 7, 2003 09:13 PM
doomgaze
Feb 12, 2003 05:55 AM
RamTuffGirl
Dec 12, 2002 11:46 PM
