Shocks ????
Old Jun 29, 2012 | 09:00 AM
tyler93's Avatar
Shocks ????
Just looking to see what you guys are using. There are so many different choices out there. Iam thinking of using the rancho rs9000 adjust. Iam running 35-12.50-16.5 on my 1993 w250. Thanks
Old Jun 29, 2012 | 09:57 AM
BILTIT's Avatar
Bilstein
Old Jun 29, 2012 | 10:03 AM
Exekiel69's Avatar
I think they are the 4900 series? I get mine from the shock warehouse I think they are the lowest price.
Old Jun 29, 2012 | 11:24 AM
bannerd's Avatar
Koni Military grade 90-1 series. I like the KYB's- GR2 as well.
Old Jun 29, 2012 | 03:01 PM
enafzige's Avatar
Don't use the Ranchos. They're next to junk for our trucks. I've had 2 sets of them before.
A non-adjustable bilstein is not a bad cheap choice. The Bilstein 7100s are the best mediocre shock for the money. If you want a good shock for these trucks, a King 2.5 is likely the best value.
--Eric
Old Jul 2, 2012 | 04:53 PM
james1's Avatar
I've never used Ranchos so I cannot opine on the quality.
Ranchos are twin-tubes and all Bilstein shocks are monotubes. Monotube is clearly the superior shock absorber technology (especially for racing applications) but they always add some degree of stiffness -- a downside for our trucks in my opinion. I'm running ProComp adjustable monotubes but if I had it to do over I would choose a twin-tube (both to save money and for the softer ride). KYB (Kayaba) makes both twin-tubes and monotubes to fit our trucks and I've never read a bad report on the quality of KYBs.
Old Jul 2, 2012 | 09:07 PM
Hodge's Avatar
I just put a set of Procomps on my truck, and like the ride.
Old Jul 3, 2012 | 12:00 AM
tyler93's Avatar
cool deal i will check em out
Old Jul 3, 2012 | 07:55 AM
elephantrider's Avatar
i run monroe heavy duty shocks on my ride.
Old Jul 3, 2012 | 02:38 PM
kiszka6911's Avatar
I have bilstiens, have to look at p/n when I get home. 5000 series comes to mind.
Old Mar 16, 2013 | 08:11 PM
ColoAngler's Avatar
I just replaced my second set of KYB565105 rear shocks. I was very lucky as the first time I didn't save my receipt and the "limited lifetime warranty" requires you have your receipt. Secondly, the limited lifetime warranty is only supposed to replace one defective shock, not the rear pair -- so you'll have one tired shock and one new shock. Third, kudos to Advance Auto Parts for replacing both of them with the receipt on the second failure of one shock. If I have to pay for another failure, I will research the Bilsteins. I see a lot of folks are pleased with them. On a side note, I am not an aggressive off road, and I'm not into high performance running. I think hitting speed bumps a little too fast or the occassional hauling of my fifth wheel trailer in very cold conditions may be the cause. Not sure.
Old Mar 18, 2013 | 12:41 AM
Tc's 91's Avatar
I have a set of the big Monroe's . Not good. I took two leafs out all around . Lowered it maybe 4" . ..That Took the hard hit out of the bottom of the shock travel. But they feel like the old 80/20 racing shocks we used to use on the front of muscle cars. Jounce isn't bad but rebound dampening is almost nothing...91/w250. Need it to ride a lot better. Getting old. I wonder if lowering it would call for a different number than the one spec'd for the truck. What to use ???
Old Mar 18, 2013 | 06:27 AM
jughead's Avatar
monroes the most useless shocks i have ever used. NEVER had a set that worked right on anything
Old Mar 21, 2013 | 06:42 AM
Mike337's Avatar
Bilstein all the way!
Old Apr 1, 2013 | 12:50 PM
HDBeauty's Avatar
Bilstein!!
whosdunit
Jan 11, 2017 01:54 AM
EverydayDiesel
Aug 19, 2007 09:38 AM
malibu
Mar 16, 2003 12:29 PM
badluck
Nov 26, 2002 12:57 AM
