Seat replacement 93 D350
Old Mar 29, 2013 | 10:33 PM
jj3500's Avatar
i've got the above truck with a tired bench seat. Looking to replace possibly with a 2nd gen bench seat.
Does anyone know if this is a easy match?
Old Mar 29, 2013 | 11:49 PM
Check the Sticky...I have a write up in there on how to do a 2nd gen seat.
Old Mar 30, 2013 | 11:33 PM
jimbo486's Avatar
I recently read that a conversion to newer truck seats may not work well in a single cab truck. If that is the case, I'm stuck with my old bench seat unless seats out of some kind of vehicle will work.
Old Mar 31, 2013 | 12:50 AM
I'm pretty sure a couple people have used my frame sketch to get a 2nd gen seat in their regular cab. Might have to alter things a wee bit, but should get you close.
Old Mar 31, 2013 | 06:50 AM
jimbo486's Avatar
Your thread was gonna be my go-to when I get around to it.
Old Mar 31, 2013 | 10:40 AM
simplysmn's Avatar
The only problem with putting a second gen seat in a reg cab truck is you would have to be a Midget because there won't be very much leg room left .
Old Apr 1, 2013 | 08:21 PM
19mike92's Avatar
i still have the original style bench in mine, i drove it like that forever until i got back in it after driving my new truck. i found the bench sat really low, so i made a seat "lift kit" 6" x 2" rectangular tubing and bolted it between the seat and the floor, more legroom, feels like the whole trucks higher and way easier at the drivethrus in a 2wd
Old Apr 1, 2013 | 08:47 PM
bryson711's Avatar
I built cow's seat frame for my crew and it fit really well, but in the end I took it out too put a set of chev seats in it with the seat belts built into the seats. I am going to put the second gen seats and cow's seat frame in my d-250 single cab. I think I'm gonna try to use the bench seat mounts and try to get them to fit good in a single cab
Sent from my DROID4 using Tapatalk 2
Old Apr 2, 2013 | 05:14 AM
jimbo486's Avatar
Keep us updated on how that goes, Bryson. I'm interested in using 2nd gen seats or maybe even Chevy seats with the built-in belts as well. I'm only 6ft tall but my legs are fairly short (damnit). I'm not sure just how much newer truck seats will change leg room as simplysmn described. I've also wondered about adapting the bench seat frame to fit newer seats instead of building a frame to fit the newer seats.
My '91.5 has 2" risers that the PO installed under the bench brackets just as 19mike92 did to his. I've only driven it a couple of times since I've owned it so I can't say I've noticed the difference between it and my '90. I just might swap them into my '90 and see what that does for leg room though.
Old Apr 2, 2013 | 10:52 AM
bryson711's Avatar
I think the chevy seats would take a lot of modding to get them to fit in a single cab. They were super easy to mock up into my crew though but it has a pretty flat floor in the front. It will be a few months before I try to put cows frame in my single cab. I will update when I do it. I hope the fit good cause I hate not having a console/armrest in it. The chev seats I put in the crew are out of a 2007
Old Apr 2, 2013 | 05:14 PM
simplysmn's Avatar
fitting the second gen seat's in a reg cab is Tight but Jim being your on the Short side of thing's you should be Ok just make sure you move it as far back as possible .
I love the second gen seat's that I put in my crewcab driver's side being power makes it nice if for some reason a short person ever drives my truck they will be able to move seat foward .
GCSS
19
Oct 24, 2015 01:56 PM
bigjohn92
Jul 15, 2011 07:01 PM
DHT
Sep 24, 2008 09:13 AM
taildragger
Dec 1, 2005 12:07 PM
bigsam
Aug 20, 2005 09:29 PM
