in search of a smoother ride
Old May 3, 2011 | 09:31 PM
GIT-R-DONE's Avatar
Originally Posted by 92smokin blacky
add some weight in the bed
X2 !
Throw 1000 lb in the bed and take it for a ride
Old May 4, 2011 | 08:59 AM
THEBIGBULLY's Avatar
Originally Posted by Rapid
I weigh in with take the load springs out and add the firestone air bags. Tremendous improvement in ride. Did this on all four corners on my mid 70's 4x4 ford 1 ton. Took out most of the spring pack, left just enough to keep the axles located safely. Added bags to it. If the ride is still too stiff you can add a small expansion tank between sides. The added capacity gives the bags more room for movement before full compression. I have these on my 350 4x4 and will be adding the two inch spring/shackle lift with custom spring brackets for the bags on the front when time allows.
I did the same thing but I took 4 leafs out of an 8 leaf rear pack.
Rides nice now.
I also added ladder bars.
Only thing with adding weight is you lose box space and fuel mileage.
Old May 4, 2011 | 09:53 AM
Subliminal's Avatar
I have the Kelderman system circa 1993.
I have bags on all 4 corners as well as the original leaf springs.
The ride is a lot better than stock, although it can be a little bouncy from time to time.
Right now I have about 2 yards of mulch in the back (couldn't get all the mulching done yesterday and needed to drive to work today) and the ride is really quite nice.
That's what I'd recommend: ~1500 lbs in the back and air bags on all 4 corners.
Old May 4, 2011 | 11:18 AM
lovemysan's Avatar
You can also install leaf spring tip inserts for about $30 plus a good drill bit and your labor. It will make the ride much less nervous in the rear and it will be slightly less jouncy but still sharp. You can remove the leaf second from the top it will help a little also. However getting into the bumpstops will result in PAIN.
I think a different set of springs with less leaves but still giving a stock ride height would be a better idea. I took out 2 leaves from my already sagging dually, it leveled the truck but it also reduced the braking traction from the front tires. <br><Br><Br><br>
You can also get some sullastic shackles for the rear. I'm pretty certain that the second gen ones will fit it if you grind a small notch in the spring mounts. As for the front suspension all you can do is install new rubber coil spring isolators and new stock springs. Sagged front springs will cause a stiffer ride. Good luck. I wish the first gens had torsen bar suspension like my 05 suburban.
Old May 4, 2011 | 08:11 PM
Dlowkes7's Avatar
any chain stores carry these spring tip liners, or anti friction pads? i really want to give a try.
Old May 5, 2011 | 01:54 PM
Midnite's Avatar
You could jack it up from the rear bumper to unload the rear suspension and then squirt some grease in between the leafs. If you notice an improvement then buy the spring tips; if not, then at least you applied some anti-corrosion treatment to the spring pack.
Old May 5, 2011 | 09:49 PM
lovemysan's Avatar
Any local spring shop should have them. We found them online for around $2 each. There are a lot of places that charge $5+ each. Personally I wouldn't do it again on the old springs. I'd probably get a brand new spring packs and have the holes professionally cut. Old springs ride hard.
Old Jun 6, 2011 | 07:49 AM
BILTIT's Avatar
Relatively cheap option:
https://www.dieseltruckresource.com/...d.php?t=224332
Old Jun 6, 2011 | 09:27 AM
mhuppertz's Avatar
Nothing like a Jim Lane write-up!
Old Jun 6, 2011 | 05:56 PM
twichit's Avatar
I understand the ride issue my girlfriend says riding in the truck is.....tiring, anyways there is yet another way for ride control. A guy on here by the screen name of Hoss installed a concrete bedliner.. just a suggestion
Old Jun 7, 2011 | 12:59 AM
9MM's Avatar
9MM
I found the best way to make my 4x4 ride good was put about300- 750 pounds in it.
Old Jun 8, 2011 | 02:15 AM
NotEnufGarage's Avatar
Spring liners and Bilsteins.
Sixpack73
Jan 22, 2007 03:19 PM
clayne100
20
Nov 1, 2006 02:44 PM
dssimecek
Jan 24, 2006 09:49 AM
BC847
Nov 7, 2005 08:12 AM
planetdell
Aug 24, 2004 08:45 PM
