1st Gen. Ram - All TopicsDiscussion for all Dodge Rams prior to 1994. This includes engine, drivetrain and non-drivetrain discussions. Anything prior to 1994 should go in here.
If a man wanted some advice on injectors based on his end goals, the feller who would guide you right so you don't play the game of bigger fuel needs more air needs bigger fuel would be Mark Wilson at DieselTuff.
He is a member here, goes by "nascar mark" - one of the founders of the old PDR outfit, solid guy, will not steer you wrong, and knows what he is doing.
My useless tip of the day (I hear I'm full of these ;-) - boil the return banjo washers & injector seals in a pan of hot water for a few minutes before reinstalling, if you cont feel like buying new ones. Of course, new sticks will come with the above.
Love the custom flip flops btw - perfectly color matched with the injector bodies
Originally Posted by Dan s
Got them out. On the way to city diesel in Knoxville now. The number one was wet all the way up. The rest were dry as a bone. They came out very easy. Someone must have been in them before I bought the truck. NOW....IF a man wanted a little bigger injectors what would he buy. Right now I'm planing on just getting stock ones.
That went on a 4 banger if my memory hasn't failed completely...
Originally Posted by boeingguy
I had a similiar problem, got a new $800 custom driveshaft, with higher critical RPM, to correlate with higher pinion angle. which eliminated issue ...
I would love a bigger set but I do drive this thing everyday and pull my camper all over the country for work. I think I would create an egt problem which is what started the turbo install. But who knows. I might change my mind before I get there. I never claimed to be smart. Lol
O fellas u keep posting right befor me. Lol. City diesel have a set on the shelf. Just gonna exchange mine. Curious as to what else they have on the shelf
You have the 9 MM injectors that go on the '89-'91.0 motors only. My understanding is all new injectors available now are 7 MM ones, which means you will need to buy adapters.
I would be careful exchanging them as it might be hard to find an actual OEM 9 MM injectors, new or used, later.
What Ofelas said, about Mark Wilson, is good advice. NascarMark knows his stuff, doesn't brag about knowing his stuff, doesn't push anything on folks. Just gets you what you need, with top notch advice to go with it, for free, with no attitude!
Just left the shop. I went with the stock ones. 9mm Had to exchange mine.
Perfect, I have heard of people buying new injectors and trading there old 9 MM in not realizing they where getting 7 MM. Then wishing they had their 9 MMs back and the shop "can't find them".
