Reverse , back up lights on when..
Sorry. 92 w250 with a a518.
I looked at the trans and there was only one plug in that I could see and it had 3 wires.
I un pluged it and the truck would not start. I figured it was for the neutral safety switch.
Yup that 3 prong plug is the neutral safety switch, and reverse lights. Unplugging it will indeed affect your truck starting. You can try a new switch, if they are still on then there might be an addition switch on the column for the reverse lights?....I'm not too familiar with the wiring set-up on the 91.5-93's.
In the tail light harness on the back of the truck. What can happen is the tail light circuit will ground through the backup lights which in turn causes them to glo just the same as the taillights. I would look to see if the ground wire has broken off.
No REVERSE-switch in the column, nor the shifter; the only switch is in the transmission itself.
The only possible cause for your situation is that already described = tail-lights seeking GROUND through the REVERSE bulbs.
Insayn
Jan 5, 2012 12:29 AM
firestorm
Jan 19, 2011 09:17 AM
nvr-enuf
Feb 16, 2010 12:58 PM
tntshrekuk
Jun 25, 2008 12:02 PM
