Return Fuel line
Old Apr 20, 2007 | 07:08 AM
pokeypennell's Avatar
Return Fuel line
Well, the truck I bought proved to have a few other small issues. I got the rearend to stop leaking by changing the pinion seal and pumpkin gasket. In the process of changing the above I broke the right rear brake line, which I got fixed but had a heck of a time getting the bleeder screw out.
Next was leaking fuel from the return line, just after the last injector. I cut the return line after the last injector and spliced in some rubber fuel line, the other line that T into the injector line that goes along the block and hooks into the VE pump? I had to cut as well. I took it off the pump and turned the banjo fitting 180 degrees and attached the other return to that, i then put a T in that line to get it up to 5/16 which is the size of the line returning to the tank. Do you all think this is a good idea, I have yet to run it but It seems like it should be fine! Any thoughts are appreciated. THanks
Nick
Old Apr 20, 2007 | 02:02 PM
bgilbert's Avatar
As long as you don't get air to enter the system you should be ok.
Old Apr 20, 2007 | 02:06 PM
There is definetly air in the system, but I should be only in the return lines, this will be okay??
Old Apr 20, 2007 | 02:12 PM
bgilbert's Avatar
Huh?
If you are worried that after doing this job you allowed too much air to enter, it could. Get out there and start the thing to find out.
Old Apr 20, 2007 | 02:55 PM
I meant, there is definetly air in the return lines, not in the fuel delivery lines. I am planning on putting it together tongiht, I will update you all on monday. I have to go to the home depot to get one more part tonight.
Old Apr 23, 2007 | 07:05 AM
Well, I went to home depot to get the last few items, got it together and no leaks!! I excited, no all is need is a power steering pump as it seems to be leaking..any good sources or tips on changing?
Rick 12v CTD
Sep 23, 2011 05:21 PM
Scotts_D250
Jul 10, 2011 01:05 AM
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
billmac
0
Mar 20, 2006 03:03 PM
