Replacing power steering pump, I have a few questions
Old Aug 4, 2006 | 03:18 PM
NoSparkplugs's Avatar
Well I must be missing something at napa since it didn't seem like they had that pump. I'm just going to take it down to an auto shop and get them to pull the piece off and press it onto the new pump. I hope this just goes in with ease after I get it done .
Old Aug 4, 2006 | 03:53 PM
Trebor's Avatar
See this link at napa:
http://www.napaonline.com/masterpage...d=7&SubCatId=5
Old Aug 4, 2006 | 04:23 PM
flashgordon's Avatar
Originally Posted by Trebor
the only worry about have a shop remove the end is, they may get i off, but hoos to say that it will ever go back on tight, to the new pump, and evan hold.......theres a lot of torque on that shaft and when your dun and have no p/s...............keep checking parts houses untill yoiu get the right one.
It's up to you but i would try and find the right pump!
maybe you can us the link above and have the pull the part number or numbers that you find!!
Old Aug 4, 2006 | 04:42 PM
dpuckett's Avatar
Ok, you have a 93, that means intercooled with the vane style vacuum pump. Unplug your oil pressure sender, and take the whole assembly (2-15mm bolts) loose from the gear housing.
Once you have the pumps off, seperate them by pulling the bolts off the p/s pump and jiggling the p/s pump off the vac pump. You should not have to have anything pressed or pulled off by a machine shop. Simple wrenches will do the job.
Upon reassembly 15min later, make sure you have a new seal to go between the p/s and vac pumps, or you will leak engine oil. Heck, pay the $7.50 to get a new vac pump reseal kit from Cummins (I'll post the p-n when I find the receipt), and redo the vac pump.
Put it all back together and bleed the system. Installation of a power steering filter sounds like a good idea. ALso, refill it with power steering fluid- FSM says not to use ATF. It isnt any less costly to put the right fluid in the first time.
Daniel
Old Aug 4, 2006 | 11:56 PM
ITS DONE!!!
Haha, I couldn't help myself. My buddy helped me out a ton and using some redneck ingenuity we got that sucker off and on the new pump. I got the new pump in, bled the system and holy heck its like driving a new truck! So smooth and easy to steer. Parking lots and cul-de-sacs don't scare me as much anymore .
Old Aug 5, 2006 | 12:04 AM
Originally Posted by NoSparkplugs
ITS DONE!!!
so was the piese prest on or splined?
Old Aug 5, 2006 | 12:17 AM
It was pressed on. A little grease and some heat helped it go on nicely.
bansh-eman
15
Sep 21, 2009 11:11 AM
SeanB23
Jun 16, 2009 12:52 AM
Gotlift01
Jun 21, 2007 02:48 PM
89dieselkong
Oct 26, 2006 10:44 PM
GoodoleBob
Sep 27, 2006 11:37 PM
